ECU error codes and fuel filter question
Old Jul 6, 2003 | 11:08 PM
MoogieBoogie's Avatar
I have a 1995 Maxima SE 5spd.
My friend and I were working on my car today. I had the check engine light come on, after resetting it two weeks ago. The codes I got were 0103 and 0908, which are both for the engine coolant temperature sensor. Does that mean both sensors are bad? From what I've read through searching, there are two sensors. How simple are they to replace?
Also, when attempting to change out the fuel filter, we removed the gas cap and tried to remove the filter. The hose would not come off. Then we removed the fuel pump fuse, started up the car, let it use the gas in the lines, then cranked it a few times after it stalled. Still, the hose wouldn't come off. Any advice on how to successfully remove the hose? He had no problem with the first method, when he changed out the fuel filter on his 1999 Maxima SE.
Thanks everyone!
-Brian.
Old Jul 6, 2003 | 11:11 PM
gabex's Avatar
About the sensors, fairly easy to replace w/ a Haynes manual in hand.
For the fuel filter, I couldn't get my hose off. It was stubborn.. I ended up paying $25 (including the filter) to have it done at some lube place.
Old Jul 7, 2003 | 08:14 PM
Anyone have a picture or a link to a picture of where they are?
Thanks,
-Brian.
Old Jul 7, 2003 | 10:51 PM
maximaseefu's Avatar
you may have to use a screwdriver or other similiar tool to pry around the edge of the hose on the fuel filter. i remember mine was tough and i had to do that. but once you get it moving it will "jump right out"
mrc00l88
Jan 25, 2024 01:14 PM
cruce91
Sep 20, 2015 10:23 AM
Johnny9595
Sep 3, 2015 05:18 AM
305head
Aug 26, 2015 09:03 PM
maxima297
Aug 3, 2015 12:50 PM
