Engine Removal Questions
Old Jul 8, 2003 | 10:23 AM
ejj's Avatar
ejj
So this weekend I'm starting the engine swap. My plan is to get the engine out this weekend, parts prepped/swapped next week, then the new engine in the weekend after.
Some questions about removing the engine:
* Leave the AC system in the car I assume? I can't imagine breaking the AC lines would be a lot of fun.
* Take the SC out with the engine? Can't imagine why I wouldn't.
* Can the alternator come out with the engine?
Any other tips?
Thanks!
Old Jul 8, 2003 | 10:26 AM
Jeff92se's Avatar
I'm needing a caw
Leave the ac compressor on. Just wire it up so you don't stress the connections.
I'd take the sc out and maybe leave the plate on. but since it's high, I don't see a problem. If you drop the engine down, then I'd definately take the sc out. But I'd take it out from the top.
Alternator is easy to take out. I'd take it out before. Plus when you have to set the engine down, you don't want it sitting on the alternator.
Old Jul 8, 2003 | 10:36 AM
ejj's Avatar
ejj
On what? The engine or car? I assume you mean leave it on the car.
I'm going out the top. You can't the the SC off the plate without taking the plate off the engine...so that would be pointless.
Good point. Thanks.
Old Jul 8, 2003 | 10:42 AM
Scruit's Avatar
U wanna try me young boy?
Leave the AC in the car. Leave the PS in the car if you can. Are you going to remove the hood or just disconnect the struts and fold it further back? Doesn't seem like you'd get much more room that way, but it's preferable to trying to realign the hood later!
Old Jul 8, 2003 | 10:45 AM
ejj's Avatar
ejj
I'm going to remove the hood.
Old Jul 8, 2003 | 11:54 AM
Dreizehn's Avatar
I removed the hood...
The AC and Power Steering, I left in the car...
Once I got the motor out, I removed the alternator.
As far as the SC goes, I'd leave it attached to the motor until you have it pulled.
Have fun!!
Old Jul 8, 2003 | 11:58 AM
ejj's Avatar
ejj
Originally posted by MadMax95
Have fun!!
Thanks for the advice.
Where did you "grab" the engine by? Mounts?
How long did it take you?
Old Jul 8, 2003 | 12:03 PM
Dreizehn's Avatar
On the front I bolted the chain to the motor mount, for the rear I bolted it into one of the tranny bolt holes.
Once I got everything off the motor, it didn't take long to get it pulled.
Old Jul 8, 2003 | 12:11 PM
cscm094's Avatar
Just curious, Why are you taking the motor out of a 1999 ? Building it up or something?
Old Jul 8, 2003 | 12:13 PM
ejj's Avatar
ejj
Just bored and looking for something to do....
http://forums.maxima.org/showthread....tterfly+screws
Matt93SE
May 24, 2019 02:58 PM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
scarletsosa
Aug 17, 2015 09:09 PM
