Sticking high idle
Old Jul 10, 2003 | 09:35 AM
Remington's Avatar
Sticking high idle
Weird problem I've had off and on. Sometimes when I pull up to a light, the idle is stuck very high ~1000. If I put it in neutral (auto trans), it jumps to 1500. I can get it to drop down sometimes by revving a couple times. Other times it just stays high. Anyone know why the idle would stick like that?
Old Jul 10, 2003 | 09:48 AM
Zirafa's Avatar
Clean your TB.
http://www.motorvate.ca/mvp.php/517
Old Jul 10, 2003 | 09:56 AM
mitchman's Avatar
I had a similar problem with my '95 5 speed. If I would let up on the throttle gradually and push in the clutch, it would idle somewhere between 1100 and 1400. If I would blip the throttle, it would then idle down to a normal speed (varies depending on whether the a/c is on or not). This went on for about 5 or 6 months and I just thought I needed to clean my throttle body again. But, eventually it threw a code for the TPS (throttle position sensor). I checked it with a multi-meter and I could get it to replicate with an incorrect voltage output if I let the throttle slowly down to the closed position. If I let up on it quickly, I would get a correct voltage output reading. If your TSP is bad, follow the shop manual instructions exactly. I didn't, and it took me forever. I couldn't get the car to idle below 1600 for an hour before I went through it step by step. Good luck!
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
