Can feel liek a clack in sterring wheel when turning
Jul 13, 2003 | 04:47 PM
When turning at slow speeds I can feel a click/clack. And the other day reversing out of my garage I ahd the wheels turned slight as I reveresed,a dn then as I went over the end of our drive way I heard likea loud ping/clack Car drives fine, but sometimes I wonder if the wheels are going to fall of or soemthing, almost liek some play or something. I see no rips or tears in the cv boots, no grease anywhere. What could it be? Thanks in advance
Jul 25, 2003 | 02:43 PM
Anybody? also the bar between the two rubber accordian things, I can jiggle it a bit? What does that mean? There are no tears in the rubber or anything but the metal bar/rod I can jiggle a bit....Is it busted? Can you email me since the forums page many times doesn't coem up for me. Thanks, I'm worried about driving and my wheels just fall off.
sergio3986@hotmail.com
Jul 25, 2003 | 06:43 PM
im curious about it too
Jul 25, 2003 | 06:58 PM
It sounds like worn out strut bearings causing spring noise due to binding.
Jul 25, 2003 | 07:31 PM
clock spring?
Jul 29, 2003 | 05:23 AM
What about the metal rod between the two boots? Is that the tie rod? I can jiggle the rod on both sides (driver/passenger) Or si that something else?
Jul 29, 2003 | 05:59 AM
lol its probably your cv joint
Jul 29, 2003 | 06:03 AM
Quote:
Those are you tie rod ends. If there loose, have your front end checked. They should be replaced and your alignment reset. Do you notice your car wonders on the highway or the steering has more play then normal? Those are all signs of loose tie rods.
Really? Damn that sucks, on both sides, damn. I don't see any grease anywhere though. Man this sucks.
Jul 29, 2003 | 06:09 AM
Ya there is play for sure and on the highway for sure. So it might just be the tie rods then, hopefully they're not too expensive....Any idea on $?? Thanks!!!
Jul 29, 2003 | 02:56 PM
If it sounds like it's coming from the steering wheel and not within the car, take apart the steering column and look in there. Mine was making a cling-clang when I turned the wheel, and someties (although less noticible) when going over big bumps. There was a dampener that had come loose and was just hanging out.
