Having a hard finding why my car is overheating
Old Jul 15, 2003 | 05:24 AM
amixam98's Avatar
Needs non-Maxima Friends
Over the last 6 months my car have been overheating off and on. I hardly drive my car and hardly go far with it. Initially, we thought it was a small leak that we couldn't find. So we didn't think it was a big deal. I finally got around to changing the hoses and that didn't help. So I changed my thermomter and that didn't help too. So over the weekend I changed my radiator, and that still didn't work. wtf? One thing I did notice is my car seem to overheat alot faster when my A/C is on. What else could be causing the problem?
Old Jul 15, 2003 | 05:27 AM
mzmtg's Avatar
Minister of Silly Walks
One of your radiatator fans isn't kicking on when the AC comes on.
Probably.
Old Jul 15, 2003 | 05:28 AM
Jatan's Avatar
Water pump?
Old Jul 15, 2003 | 05:32 AM
amixam98's Avatar
Both fans are working ok. Water pump? That might be next move. How do you know if your water pump is bad? There's no leak. Anyone else?
Old Jul 15, 2003 | 06:38 AM
deezo's Avatar
3 things you should look at which is the radiator, thermostat and water pump.
If your not getting leaks from the waterpump, it can't be bad. Usually the bearing goes on it.
Old Jul 15, 2003 | 07:20 AM
fisher01's Avatar
Is there a temperature sensor which tells the fans to turn on? I rememeber replacing this sensor when our older maxima was over heating.
Old Jul 15, 2003 | 12:53 PM
kdarci's Avatar
I've had the same problem with my 97 GLE. Last summer it got really bad, and I replaced the radiator, thermostat and the water pump bearing(s). Fixed the problem.
This summer, it started again - but I noticed that if I don't try to accelerate too hard, the temp. gauge goes back down - or if I maintain a constant speed. The temp. gauge starts going up in stop-and-go traffic or if I accelerate too hard.
Would like to know what you found out that works! I'm leery of taking it in for service, due to the problem last summer (filed a suit against the dealership since they replaced 2 parts that were perfectly fine - always ask to keep your old parts!)
Old Jul 15, 2003 | 03:44 PM
Max Noob's Avatar
therostat, water pump, radioor
to check water pump, have the car cold pref in morning.. open the radior cap. turn on the car. see if the coolant is beignpumped. u can compare the speed to one of your other cars with a good pump. goodluck bro..
kdarci.. try going to a different dealer in the area??
Lakersallday24
Jun 16, 2019 01:35 AM
Wolvee
Aug 11, 2015 12:24 PM
Gsantos79
Aug 8, 2015 07:41 AM
