car wont start. need some help.
Old Jul 15, 2003 | 09:20 PM
PsyKotiC RydeR's Avatar
first of, its a 99 maxima se auto with no mods. stock.
car started fine and drove fine yesterday morning when when my mom tried to go out the car didnt start in the evening. the car cranks and its trying to start but nuttin. so i put in a new starter today and started the car. as soon as it started it shut right back off by itself. it did this about 5 times and the car is back how it was last night. ne idea what the hell it coud be? this ****ing car is stuck on my driveway and i cant take my car out till i get this thing moving. inputs are welcomed
Old Jul 15, 2003 | 09:52 PM
i need to get this **** moving asap. ne techs on this board?
Old Jul 15, 2003 | 10:40 PM
HarrisH's Avatar
Not trying to sound stupid if you really need to move the car put it in neutral and move it. Secondly I'm guessing your starter's connectors are loose try banging on the starter and try staring it see if it works then.
Old Jul 15, 2003 | 10:45 PM
maximaseefu's Avatar
yeah sounds like either connectors on starter are loose or alternator crapping out.
Old Jul 15, 2003 | 11:51 PM
MoogieBoogie's Avatar
He would simply move the car if it was possible, but the driveway is a decline, angling down towards the garage where his car is parked. Moving the car would be pretty hard to do.
Would the starter connectors being loose cause the car to shut off immediately after starting up?
-Brian.
Old Jul 16, 2003 | 12:16 AM
sbslacker's Avatar
Clogged fuel line/filter maybe? Bad gas? When you did get it started, did you give it gas and have the motor cut off immediately? Just guessing...
Old Jul 16, 2003 | 04:36 AM
njmaxseltd's Avatar
Check your ECU for error codes.
Most likely you have a crank shaft position sensor failure. There's two sensors, one is called POS for position and the other is called REF for referance. If either of those fail, your car wount start. Sometimes the ECU will not throw the codes either. You'll have to check both sensors manually to figure it out.
There's also the possibility of the camshaft position sensor causing a no start condition as well.
Bottom line, you need a Haynes manual to see where and how to test these sensors. Go to the closest book store and pick one up.
Old Jul 16, 2003 | 09:20 PM
thanks for the info guys. I towed it to my shop and it seems like its either one of the sensors or could be both. and yea my driveway is a hill!! so i cant push it out but i got it towed to my shop so its all good. hope to fix this damn thing and put it back on the road this week.
btw, i just did a tune up along with new plugs, fuel filter, pcv, and so on about a month ago.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
N2deep
Aug 16, 2015 08:30 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
