How to Install Air/Fuel guage in max?
Old Jul 16, 2003 | 08:19 PM
bobjohnson's Avatar
Blazin......
I believe you just run a wire to a sensor which monitors the air/fuel , but im skeptical as to which on it is.
Any Ideas??
ALso . has anyone put a oil temp sensor on ur maxima. im not wanting to drill the pan unless i have to .
thanks alot. mwest
Old Jul 16, 2003 | 08:34 PM
jcy98maxse's Avatar
Turbo is too much fun!
Run the signal wire of the A/F gauge mine was purple, to either the o2 sensor signal off the ecu or to the actual sensor.
Old Jul 17, 2003 | 09:36 AM
bobjohnson's Avatar
Blazin......
Yeah but which o2 sensor, WE Have 3 O2 sensors to choose from..?????????
Old Jul 17, 2003 | 09:55 AM
ejj's Avatar
ejj
Which ever you want to monitor. You've got to pick one. I picked the left front, just because its easy to get to the sensors wiring harness.
Old Jul 17, 2003 | 12:05 PM
jcy98maxse's Avatar
I did my thru the ecu, I had it tap in with one of the o2 sensor wire that I had connected for my safc.
Old Jul 18, 2003 | 01:01 PM
CullenJ76's Avatar
do not wire to the o2 sensor. it WILL NOT be accurate! for a full diagram of EXACTLY where to wire it on your ecu click on the diagram section of this website www.hlh0501.com
hope I helped,
Cullen J
Old Jul 18, 2003 | 03:17 PM
bobjohnson's Avatar
Blazin......
Thanks But I have 2 Questions.
#1 do you splice the wire that runs in there and attach it OR do you physically car ram-rod that wire into the hole with the other wire still there.
#2 this is the ecu by my drivers-side feet right. And im gonna take it out to do this? or can i leave it in and go from the passenger side.
Thanks guys. much support.
Old Jul 18, 2003 | 03:19 PM
Redmax's Avatar
Redlinemax Owner
but is it accurate if you wire it to the ecu
Old Jul 18, 2003 | 04:24 PM
bobjohnson's Avatar
Blazin......
yep he said it was.
So do i car ram-rod the wire in the same hole.
Old Jul 20, 2003 | 11:39 AM
CullenJ76's Avatar
www.hlh0501.com shows you EXACTLY where to wire it. very simple and yes that IS as accurate as you can get(ECU)trust me. I'm **** when it comes to things like this.
Old Jul 20, 2003 | 03:36 PM
guestNX's Avatar
You can access the wires for the ecu, on the passenger side of the center console. Remove the plastic kick panel, then the center bolt attaching the wire harness to the ecu. Pull the white/clear plastic cover off of the wires, and trace down ONE of the two red-outlined pins from the diagram. Attach your purple lead from a/f gauge to one of those two wires, using just a wire-tap.
Goodluck and enjoy. Oh, and do not freak out when your a/f gauge bounces all around when cruising etc, it is only accurate when you are throttling on it a decent amount.
Old Jul 20, 2003 | 04:40 PM
WizzaMax's Avatar
light show...= useless tool...just my rhetorical post...
Old Jul 20, 2003 | 06:27 PM
Jime's Avatar
Its only as accurate as the narrow band O2 sensor you are hooking up to. It varies with temperature and is only accurate over a very narrow band it is no good for boosted engines where the A/F is in the 12:1 range.
If you want accuracy you need a wideband O2 setup and they cost money.
Old Jul 20, 2003 | 07:13 PM
ejj's Avatar
ejj
It serves as a great "spacer" in your guage set up though, if you're waiting for a more useful one.
Old Jul 20, 2003 | 08:56 PM
Lonely Driver's Avatar
If you already have an a/f gauge, can you just buy a wide band sensor and hook it up to that instead of the oem sensor? Or would I need a different setup?
dank4us
34
Jun 10, 2024 03:45 AM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Stagnet04
Aug 30, 2015 07:30 AM
95Maxi
Aug 25, 2015 08:01 PM
