Need help, in the process of clearing tail lights
I'm in the middle of clearing out the amver in my tail lights. i'm not to sure what part to heat up. Can someone help me out. I know it says the housing but where the hell is that?? Well if someone can help that would be great.
Max99
Max99
BrianV and a big bucket of patience.....
https://maxima.org/forums/showthread...threadid=21669
https://maxima.org/forums/showthread...threadid=21718
I'm the only one who is flamed for using this can you guess what is it is........? But it does work but BrianV is an expert on this subject...
Here is what i did, turn the tail light asembly over and lay it lense down on a towel so you do not scratch the lense. Heat the perimeter of the bezel (where you removed the five very small screws, the black/dark gray plastic)slowly. Do not get the heatgun too close and keep the heatgun moving. The glue used to hold the assembly together is like "hot-melt" glue used in crafts. It doesnt take to long at all to warm it to its melting point (couple of minutes). The plastic used to make up the housing (black) will act as a conductor of heat and stays warm for a while. My only word of caution for this mod is to take your time when seperating the lense from the bezel. Let it get good and warm before pulling the lense off. If you feel any resistance stop! And warm it up again. The lenses are made of a somewhat brittle plastic and they will crack if you are not careful. Let the heatgun do the work. I have to replace one of my lenses because I put too much pressure on it while seperating it. Courtesy Nissan price for just the outer lense: $77.14....so
take your time.
take your time.
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
