Need help! Oil Leaking (esp. enging rebuild guys)
Old Jul 17, 2003 | 10:46 AM
maxhead's Avatar
My co-worker has a 95 Max. She has a leak coming from somewhere on her engine. Her mechanic (I think he's shady) told her that she needs some type of flex pipe and wants to charge $325. I usually know about cars and want to help but I have no clue what the he** the mechanic is talking about.
She's getting back in touch with him now to get a more specific explanation but I figure I'd check here to see if that sounds familiar to any of you. A bad flex pipe that is causing oil to leak or "drip" as her mechanic stated. Any ideas?
Old Jul 17, 2003 | 11:45 AM
Dreizehn's Avatar
Need more info...
The flex pipe thing doesn't sound right. Unless it's a turbo oil drain...
Old Jul 17, 2003 | 11:47 AM
maxhead's Avatar
Originally posted by MadMax95
Need more info...
That's what I'm thinking. In all of my days, I've never heard of a flex drain. No turbo on her car. Any other ideas?
Old Jul 18, 2003 | 09:54 AM
Little95Max's Avatar
Are you sure it is engine oil that is leaking? It might be power steering fluid. I think there is a flex pipe going to the pump. Mine is leaking now.
Old Jul 19, 2003 | 08:45 AM
maxhead's Avatar
Yeah...that's what he told her. She confirmed she has to keep putting motor oil in. I didn't have time to look under the hood, but I saw the fresh oil stains. It's coming from the passenger side of the car...right about where the oil pressure switch is.
Has anybody heard of this 'flex' pipe for oil or is this mechanic a quack?
Old Jul 19, 2003 | 09:37 AM
Street Reeper's Avatar
Handsome
Check the oil pressure switch, it is known to leak on the 4th gens.
http://www.motorvate.ca/mvp.php/514
Also has her PCV valve been changed? My Max was using oil, changed the PCV and it is holding great.
I pretty much guarantee that one of these is the problem. If she see's oil under her car (put a white towel under the car at night) then it is probably the switch, if she does not it is probably the PCV. How many miles does she have and has she had the dealer do her 60,000 tune ups? My car is under warranty do I need a paper trail so I had to get the dealer to do the tune up, they DID NOT change the PCV valve which caused my problems (it was not in the list of things they were going to do, I would check.)
Hope this helps.
Matt93SE
May 24, 2019 02:58 PM
maxprivate
Nov 29, 2017 08:52 AM
rtirbany
Sep 8, 2015 11:46 AM
maxipower
Aug 21, 2015 11:10 AM
carlosvq30
Aug 17, 2015 11:32 AM
