Hey everyone. I'm attempting to fix my rear timing cover oil seal, and both oil pans. I have both the chilton and haynes manual. Anyone have any suggestions with the timing and what not???
Chris
Chris
Which seal are you trying to replace?
The front main oil seal?
The oil pan front and rear seal?
Or are you just trying to reseal the rear timing chain case to the block?
I'm trying to reseal the rear timing chain case to the block. Also reseal upper oil pan and replace lower oil pan(dented in my curb).
Quote:
The oil pain is going to be a lot easier than the timing chain case. Originally posted by NISMOPower
You'll have to remove the passenger side motor mount to get the the timing chain case off. I have heard a couple people mention jacking up that side of the motor for some more room but I haven't personally done it. Hopefully someone who has changed the timing chain can chime in.
I have a couple of pics on my homepage of the timing chain case off if you want a look at it. Unfortunately the motor is on an engine stand so you won't get a good idea of what you're in for.
Hope this helps.
