IACV what does it do?
Old 07-20-2003, 06:50 AM
97MaximaSE's Avatar
Sometimes when i put my car in reverse or drive or im just sitting at a red light it stalls. Sometimes the rpms bounce a little and then settle. Does the iacv control this or is it controlled by something else? Im just wondering if i should try another iacv or if the problem lies elsewhere.
97MaximaSE is offline
Old 07-20-2003, 08:19 AM
ESLEECK
it could be the problem, it controls the airflow at idle hence the name "idle air control valve" but usually if your iac is bad it will give you a mil
Old 07-20-2003, 10:17 AM
97MaximaSE's Avatar
well the car is barely driveable today....its stalling at almost every stop. im going on vacation in less than 2 weeks so i dont know what else to do
Old 07-20-2003, 11:16 AM
nismology's Avatar
Sorry to ***** your thread 97MaximaSE but I would really like to know where this valve is located so I can clean it.
nismology is offline
Old 07-20-2003, 11:58 AM
2naboy's Avatar
It may be your mass air flow meter. It does that sometimes so check that too.
2naboy is offline
Old 07-20-2003, 06:57 PM
97MaximaSE's Avatar
i replaced that already so i know its good.....i just moved the wiring harness and it stalled so i think i know what it is now....i hope
Old 07-20-2003, 07:36 PM
U wanna try me young boy?
Scruit's Avatar
Clean your TB. Do a search on Clean TB and you should find instructions.
Scruit is offline
Old 07-20-2003, 09:16 PM
97MaximaSE's Avatar
if i clean my tb and iacv anymore i will be able to see myself in it....im sure now its my wiring harness. the car shouldnt stall or come close to it when you move your wires
Old 07-23-2003, 06:45 AM
TitleistPrto's Avatar
How do you take out the IACV?
TitleistPrto is offline
Old 07-23-2003, 07:04 AM
Jatan's Avatar
http://forums.maxima.org/showthread....highlight=IACV
Jatan is offline
Old 07-24-2003, 10:45 AM
cam_honestiam's Avatar
First thing you want to check is fuel/air filters. Then go ahead with the other prescriptions.
cam_honestiam is offline
Old 07-24-2003, 11:55 AM
FLO_BOY's Avatar
ANOTHER ONE LIKE ME!!!
I had this EXACT SAME PROBLEM!!! took me a year to properly diagnose.
search for threads started by me with "MAFS" or "Wiring" in them, and
you'll see my endless search to correct the problem.
As it turns out, the wiring to the MAFS in the wire loom,
right near the passenger side strut tower, was cracked --
right where the loom bends toward the firewall...even
though, it had never been opened!!! I had the similar
issues, and also experienced pee-poor fuel economy...
what I did to diagnose the problem was shake the wires in
various places to try and isolate where the problem lay...
since it's been fixed, my car runs like a dream!
oh, and the dealer told me the problem was "100% torque convertor"...
and that it would cost $1600+ to repair...it actually cost me about
$200, as I had an electrical place do the repair for me.
good luck!
FLO_BOY
FLO_BOY is offline
Old 07-24-2003, 06:11 PM
97MaximaSE's Avatar
good luck!
FLO_BOY
well they fixed my maf wire and the car runs great but now i get front left and right o2 sensor heater codes
Old 07-24-2003, 09:10 PM
FLO_BOY's Avatar
Can you tell me where the break occurred?
Do you have any idea what may have caused it?
The only reason I finally found out the REAL issue is that the
Infiniti Parts Manager (SOOOoooo much better than Nissan!) told
me that my break had happened once before.
thanks!
FLO_BOY
FLO_BOY is offline
Old 07-25-2003, 09:47 AM
97MaximaSE's Avatar
[QUOTE]Originally posted by FLO_BOY
thanks!
FLO_BOY
[/QUOTE
right before the wires go into the firewall along the passenger side...
Old 07-25-2003, 02:11 PM
97MaximaSE's Avatar
thanks!
FLO_BOY
the guy at my nissan place said it was caused by the engine moving everytime you hit the gas. i guess our harnesses were too tight and the engine would pull the wires. he showed me the tsb and there is also an upgraded kit for new clips that should stop it from happening again. best part was he only charged me 40 bucks to fix it and that kit is only gonna cost me 12. pays to have a friend work at nissan ....email me and i will give you more info you always seemed to have the same problems i had and at least now we know whats wrong with it...i guess that maf ground was just a band aid fix
schmellyfart
09-25-2015 04:47 PM
junito1
09-23-2015 12:14 PM
bumpypickle
09-20-2015 08:22 AM
Jamie Bowen
09-06-2015 09:59 PM
nbstriker10
09-04-2015 04:26 PM
Quick Reply: IACV what does it do?
