Gear Lube
Old Jul 25, 2003 | 09:15 PM
99maximase's Avatar
Gear Lube
My 99 5 spd isnt shifting as smoothly as it use to, into 5th mainly. I think im going to change the Gear Lube using Mobile 1 synthetic gear lube which is 75w90 I think.
First of all this stuff has been sitting on my self for about 2 years, but it hasnt been opened and I doubt it would expire...right?
Also in order to change the fluid is there some plug to pull or wat to get the old fluid out? How many quarts do I need to put into the car in order to replace all the old lube?
Thx in advance
Old Jul 25, 2003 | 09:53 PM
Dev's Avatar
Dev
shouldn't be expired...since it sits in the car for a few years itself
you'll need about 4.5 quarts of fluid
there is a drain bolt you can take off...or a sensor (which is more easily accessable)
check out the write up on www.motorvate.ca and http://cardomain.com/id/stygianmax
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
