In for an oil change...Out with service enging light
Went in to get an oil change. My max has about 61,000 mile on it and I treat it as if its my son. (tune ups,cleaning etc) When I left It felt sluggish but I figured it was due to the change. The next day I see a light on my dash a light I didnt even know was there... SERVICE ENGINE SOON!!! . Now I mechanically challenge but reading the post gives me the gist of a few things. So I check my dipstick and see that the oil is about 2inchs above the 2nd cringe of the stick could this be it???to MUCH oil. Hes closed today but I want to be armed with suggestions when I see him tommorow. Thanks in advance:
Greg
Greg
Make sure you were checking the oil correctly. Checking the oil in a warm/hot engine will not give you accurate levels. Check it in the morning before you start the car, that is best.
And do what 95CustomMaxima said, pull the code and check what's wrong first. It might be completely unrelated and just plain coincidence ... you will have no reason to blame the check engine light on the shop if the failure code is unrelated.
Ok,heres what I got 5,9 (undefined) 3,4 (Knock sensor) and 11,3(Impropor shift to first gear). If this was your Max what would be your next step??
Learning Post by post
Greg
P.s Thanks for the info kevlo911 will print and bind tonight.
Greg
I ran the codes again and again and now Im geting a steady 3,4 (Knock sensor). So off I went to the Mafia I mean Dealer. 164 bucks!!!. Oh sorry $178.23 NY tax. I asked the guys at the service desk "how much would they charge" he quoted me $314 bucks. Just to pop this baby out and pop a new one in. Going to Sears tommorow to get what I need and doing this one myself. Gotta start somewhere. Thanks for all the help.
http://www.skippynet.com/maxima/knocksensor.htm
Using this as an outline to change KS
You can get KS's cheaper online. About $130 from online Nissan dealers giving 25% discount or about $100 on eBay. If you haven't opened it, see if they'll take it back (just say you didn't need it) and buy it online.
Do it yourself, here are the directions: http://www.motorvate.ca/mvp.php/507 and http://www.skippynet.com/maxima/knocksensor.htm
Thanks JaTaN I just opened it up
Thats Ok. Just the satifaction of doing this thing by myself is worth the $30. bucks
The site you gave me is more in depth and I will use that one for an outline thanks for your help
Ok got the sensor and went at it. It was a B**c* to get off but after about 2hrs and a six pack it came loose.
Had to wait another hr to let the engine cool and the rest was a snap
.Got a little worried because after the swap I still pulled a 3,4 but after a day or two of driving I got the ever so beautiful 5,5 (all clear). Thanks to all who responded and helped me through this. Im new to the do it yourself thing but thanks to all I got a confidence boost and saved some cash
maxprivate
Nov 29, 2017 08:52 AM
MatthewsMaxima
Sep 11, 2015 03:21 AM
Good luck with it
