smoke !!!
Old Feb 5, 2001 | 05:07 PM
MR_Maxi's Avatar
This is really wierd, and wondered if it has happened to anyone else, I have noticed recently that on occasions a light puff of smoke comes out of my steering column when you start the car. I haven't pulled it apart yet cos I've been pretty busy, but something must be arcing.(Happened 3 times in da last 2 mths) Any info on this would be great.
Old Feb 5, 2001 | 06:15 PM
gtr_rider's Avatar
192.168.1.1
WT????
That does not sound to good to me cuz if smoke is coming out of our steering column then you've got a problem
Old Feb 5, 2001 | 07:26 PM
MR_Maxi's Avatar
Tell me about it, it's got me f4cked !!, jus worries me cos i have an airbag, and am not too keen on getting a nose job !!!!
Old Feb 5, 2001 | 07:30 PM
BRIGBOY's Avatar
Your airbag is about to BLAST you!!
Just kidding, I hope for your sake anyway. The same thing was happening in my friends mustang when he installed a Grant steering wheel. It smoked because the wiring came loose and came in contact with something metal when he turned the wheel. A spark would ignite in there and small puffs of smoke would rise out. I wouldn't suggest going in, unless you know what your doing. Try to get Daniel B. Martins attention on this if you need good advice.
Old Feb 5, 2001 | 08:15 PM
Daniel B. Martin's Avatar
I've never had this experience. Frankly, it frightens me. Where there's smoke, there's fire. Something inside your steering column is roasting. Check with the dealer. Ask if there is a Technical Service Bulletin on this problem. Make the dealer service advisor understand this is a potentially serious safety defect. That should motivate him to take your complaint seriously.
Old Feb 5, 2001 | 09:57 PM
Kashoggio's Avatar
it could be some wires touching together and causing a small spark with some smoke.
Old Feb 5, 2001 | 10:52 PM
twankz's Avatar
First, check you air filter, that is most likely where its coming from. Change your oil that could also be the problem. Its not the steering column thats smoking, its some malfunction in the engine and the smoke creeps its way inside the car. My advice is to examine the car with the hood up and let it run for a while, you will more than likely find where the smokes from.
Also, check to see if you drop the weed on the floor while you were driving. That happends to me a lot.
Them 5-0s be phuken with me!!
GL
Old Feb 5, 2001 | 10:56 PM
Kashoggio's Avatar
air filter?? huh is smoke was coming through it would we from under the stearing cloumn not from it.
Old Feb 6, 2001 | 03:14 PM
MR_Maxi's Avatar
LOL !!!!
It may well have been grass, those buds get in everywhere !
Could be shorting on some wiring, and sending me lil ghostsies whilst driving.
Old Feb 6, 2001 | 03:22 PM
Jeff92se's Avatar
I'm needing a caw
As someone who has taken apart his entire dash to replace the heator core, it's not that hard just to remove the covers that house the steering column. It's about 4-6 phillips screws. You will probably have to fiddle w/ the covers in order for them to clear the upper speedo dash portion but it should come out.
homewrecker
Sep 24, 2015 07:01 PM
ballerchris510
Sep 10, 2015 09:35 PM
FlaMark
Aug 21, 2015 11:06 AM
Balkins
Aug 12, 2015 06:39 AM
