springs...
Old Sep 15, 2000 | 10:08 PM
Supa Lao's Avatar
My friend loves the way how my stock springs feel. I like how they feel too. Are there springs out there that just drop the car, and have the same rate springs as factory? or am I better off just getting the H&R springs?
Old Sep 16, 2000 | 04:29 AM
Micah95GLE's Avatar
Well, you can't effectively lower the car and have the same-rate springs; the car would bottom-out a lot. The H&Rs are your best bet. Do you know of anyone with a Maxima with H&Rs that will take you for a test drive?
Old Sep 16, 2000 | 12:05 PM
Supa Lao's Avatar
I think would be able to find someone w/ H&R springs that would let me sit in there car...
hint hint delio
Old Sep 17, 2000 | 12:12 AM
gotricefo's Avatar
hey Micah95GLE...
is that what your car looks like with the eibach 1.5(front)/1.3(back) dropped?? or did you cut the springs too.. because i just ordered my eibach and i'm just curious about how it looks?
Old Sep 17, 2000 | 06:35 AM
Micah95GLE's Avatar
No cutting. That's what they do right out of the box. In fact, I had them installed a little over 2.5 years ago, the first week that I had the car. So they might even be the old 1"-drop springs (I was unaware that Eibach was gonna release new 1.5"-drop springs, so I didn't bother to check which ones I got).
Old Sep 18, 2000 | 02:33 PM
ravevious
i don't really recommend to use the stock spring. what i have for my car is " ground control " which lower my car 4" then i use Eibach spring. the most important thing is shock . i replace the old with KYB . " Enjoy the ride"
Old Sep 19, 2000 | 04:01 PM
96BLUMAX's Avatar
Which brand do you think is the best for springs and how much should I have it lowered?
Old Sep 19, 2000 | 05:08 PM
ravevious
well, Eibach is one of the best spring. it's up to you to make a decision. but saty away from Intrax. they said that they can lower the car for 3" that's not true. You will looking at 250.00 - 400.00. how much should you lower it? well, i lower it for 4" but that's mean you have to install the coil over. there's 2 brand that i know one is Cattman Performance the other one is Ground Control. there's no spring that can lower Maxima more than 2.5" if you don't use the adjustable spring.
Hornswoggler
Jun 27, 2004 04:18 AM
Dev
Oct 9, 2002 08:37 PM
maxJATT
Apr 20, 2001 10:18 AM
Nick97SE
Feb 16, 2001 01:57 PM
