installing guages (not my strong point)
i have no problem doing any installs but this one.... these gauges im confussed, as to where the oil pressure sending unit is i can tie into
and what wire(s) on the ecu tie into the tach
im all set with my vacuum gauge i got that one covered lol help me out here doods lata, BRIZ
Sending unit sticks out of the oil pan. The shape of the oil pan points right to it its a harness. Drain the oil, Unclip it, unscrew the fitting, replace with appropriate T fitting and reinstall sender unit.
Any one else do the oil press any other way????
Originally posted by brizsblackmax
use a t fitting? so the oil's pressure is read mechanicly by travelling from the sender to the guage? whats if it leaks lol
BTW, you don't have to drain the oil to do this. You will only leak out a couple of ounces of oil at most.
hey, tell me where you got your guage plate from or ill, ill just tell me lol its really cool or is it steal custom fabbed?
MaxLife17
Jun 27, 2019 01:37 PM
lowpost99
Sep 8, 2015 05:06 AM
