YIKES!! hte knocking noise is BACK!!
Old Aug 5, 2003 | 10:27 AM
Kevlo911's Avatar
Kevlo for President
i was cleaning the IACV today and when i turned on the car again, i noticed that the whirling/knocking type noise is back in hte timing chain area. i got the TSB done a few weeks ago at the nissan dealer for 250 and now it seems as if hte noise is back. i called hte dealer and they said their so called machanics have to listen to it. what else could this noise be? bad steering pump, water pump
if it is hte timing chain tensioner again, the dealer should replace for free, correct?
Old Aug 5, 2003 | 10:30 AM
Zirafa's Avatar
Dealers do not repare stuff from TSBs for free - only recalls.
Old Aug 5, 2003 | 10:32 AM
Kevlo911's Avatar
Kevlo for President
well i got hte TSB done about 2 weeks ago and the noise is back
Old Aug 5, 2003 | 10:44 AM
delerium75's Avatar
If it turns out you're having problems with the same thing they worked on, then it should be under warranty since dealers usually warrant their repairs for 12 months/12,000 miles...at least at my local dealer. Show up with your receipt.
Old Aug 5, 2003 | 10:51 AM
kenju4u's Avatar
Thats right. If you just got it repaired you are still under warranty. If they say its something else then you can decide on your own if u want them to do it or do it yourself.
Old Aug 5, 2003 | 02:00 PM
Kevlo911's Avatar
Kevlo for President
i read htat some people used thicker oil--15w 30, 20w 30/or 40........and hte noise went away. should i try that before a drive an hour to hte dealer? i ONLY have 86k miles
Old Aug 5, 2003 | 04:26 PM
s0ber's Avatar
I had that noise, I changed the power steering pump and some tensioner there... good luck.
Old Aug 6, 2003 | 09:21 AM
mr2good's Avatar
Anyone else have any fixes for this problem?
Old Aug 6, 2003 | 09:27 AM
Kevlo911's Avatar
Kevlo for President
i am taking it to the dealer tomaro afternoon to see what the problem is. hopefully its the same thing so i get it done for free.
Old Aug 6, 2003 | 10:25 AM
seegarman's Avatar
Could be almost any one thing or a combo of things. My whirling noise maker was the starter! I occasionally hear the timing chain rattle at startup too. Lately, another whirling sound has started so it may mean something else is failing.
Old Aug 6, 2003 | 04:05 PM
Kevlo911's Avatar
Kevlo for President
mine is continuous at idle
JRod28
Dec 29, 2023 09:56 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
boomerbrian
Nov 8, 2015 05:10 PM
maxinout93
Oct 27, 2015 01:29 PM
Slamrod
Sep 3, 2015 07:38 PM
