Review: Rota Sub-Zero & KYB Struts & Kuhmo 712
Old Aug 8, 2003 | 10:33 AM
z30maxima's Avatar
Hey all, I just put my sub-zeros on and I am disappointed. The center caps are not even close to fitting... Has anyone else ran into this problem? I have the 45mm offset, they look great and ride good (once I find a shop to align my front wheels) but, there is about 3/4 of an inch too small. I also was experiencing hard bumps when I go over even the smallest hole or dip in the road. I have my struts set on 4-front (no fstb) 5-back (rsb) w/ sprints 2" drop. As for the driveabilty issues, this car does not drive like a OEM maxima as you would suspect with the mods on the suspension. Cornering is as smooth as say...B M W !!!! Really though, the car drives excellent on or off the highway, seemlessly swerving through rush-hour traffic is a breeze too. As for mph and/or acceleration, I would say that these mods definatly made the 0-20,0-60 and 1/4 mile times all drop tremendously, due only to the car's ability to stick to the ground like epoxy.
My (suspension only)setup includes:
17" Rota Sub-Zero 16.2 lbs. 2nd gen Gunmetal w/ Silver Lip
Kuhmo Ecsta 712 235/45/17 Z-rated
Progress RSB
KYB/AGX 8-Way Struts
This car isn't the same anymore...bye bye Mr. Type R Integra!!!!!
Old Aug 8, 2003 | 11:24 AM
dizmax96's Avatar
i got 18" subzeros
yeh i got 18" gunmetal sub zeros.. the front center caps fit.. the rears dont.. ive been too lazy to shave the inside of the rear caps a lil bit to fit the center cap.. as for bumps.. i dono.. ar takes some hard bumps.. i have my fronts at 3 and the rear at like 7 .. i have H&R springs wit AGXs.. i have 235/40/18 tires.. maybe your takin the hard bumps becuz your car is a lil bit lower? im not sure.. im jus sacred my wheels are gonna get bent going over hard bumps.. but since the tire is 235/40.. i should be ohk.. hopefully..
Old Aug 8, 2003 | 11:29 AM
njmaxseltd's Avatar
Re: Review: Rota Sub-Zero & KYB Struts & Kuhmo 712
Your 17" wheels plus the line below is the reason why.
Tremendously, I'm sure
Old Aug 8, 2003 | 11:38 AM
SeanNY's Avatar
Old Aug 8, 2003 | 01:28 PM
happyricefob's Avatar
V^___^V
waz ur settin on ur AGX? cuz i mite jus pick up a GR2 over sprint. GR2 = 2 in the front, 4 in the back on AGX. jus curious.
Old Aug 10, 2003 | 01:14 PM
z30maxima's Avatar
Well, it stated my setup in the first post, so look there.
Old Aug 10, 2003 | 01:34 PM
A-Ron Max's Avatar
My center caps didn't fit, just found some other ones that did. Check my homepage for pics.
Old Aug 10, 2003 | 03:58 PM
z30maxima's Avatar
tru bro, thanx!
Old Aug 11, 2003 | 09:58 AM
z30maxima's Avatar
Re: Re: Review: Rota Sub-Zero & KYB Struts & Kuhmo 712
Originally posted by SeanNY
You were trying to say something??? What?
don't mean too much..might want to clear that one up dude.
Old Sep 13, 2003 | 12:23 AM
bellis's Avatar
I had the same problem My backs stayed and fronts are gone. I had to use a grinder and shave the inside down. but they did not stay. bad design!
I have the 16" slipstreams. 13.5 ls each they are nice.
Old Sep 13, 2003 | 02:51 AM
SXN's Avatar
SXN
like this much *holds out arms far apart*
and for the center caps, just shave the inside a little, but keep checking so the fit remains niiiice and snug
Old Sep 13, 2003 | 09:45 AM
ThurzNite's Avatar
18x7.5 45mm rota subzeros
235/40-18 kumho 712
no other suspension mods. Pretty good ride and grip for the price ($500 rims $500 tires). I can't say it accelerates better cuz this setup weighs more than stock steelies and more weight resides @ the rim than center. However, braking is much improved with new grippy tires. There is a good amount of road feel through the rims/tires with my stock setup, and I hope to get more feel when I get agx/gc later.
Maybe you've read my other thread, but i'm getting oversteer right now. 36psi all around. What do u guys run with 235/40-18?
Jae
btw, i left the centercaps off. The fake CF/plastic look cheazy w/the nice rims.
And I'm not happy w/the rims themselves. 7.5 wide shouldn't be paired with 235wide...too narrow. And 45mm offset won't clear any big brake calipers.
Pnjboyzz
Nov 16, 2015 12:27 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
