Another Interior lighting question :-)
Old Aug 12, 2003 | 09:17 AM
GodsmackMAX's Avatar
Hey all, I have a 97 GXE, and I just completed the door switch LED conversion to blue. This looks really awesome! Kudos to whoever figured this one out!
Well, now that I have the door switches converted, the rest of the interior lights obviously dont match So, what is the proper LED to use for the security light? I have searched on the test forum, and I have come up with two responses. Some have used the 3.7V and some have used the 5V LED. The people with the 3.7V, some of them have had it blow out and others have had it work fine. So what is the real answer? Should I just go with the 5V? What is the part number please?
As for the other interior lights, has anyone figured out a way to change all the center console lights to blue? I read somewhere that someone was going to use glass spray paint from walmart? Did this work?
Thank you for any responses!
bluemaxdriver4
Old Aug 12, 2003 | 09:28 AM
araffio's Avatar
I just put in a blue 5V LED for my security light last night. I got it at Radio Shack for a couple bucks. That is the proper voltage if I am correct. Looks sweet
I wish I could do my window switches but I don't think it cn be done on a 98
Old Aug 12, 2003 | 06:58 PM
Thanks for the response!
What about the other lights? Has anyone experimented with this glass paint or whatever it was? Are the lights behind the center console LEDs or bulbs?
bluemaxdriver4
Old Aug 12, 2003 | 07:03 PM
araffio's Avatar
I would think that glass paint would block too much light, the bulbs behind the dash are dim as it is
Old Aug 12, 2003 | 07:08 PM
So as of right now, there is no know swap for blue lights behind the center console?
Old Aug 12, 2003 | 07:10 PM
z-dan's Avatar
the complete thread Here
Credit to 97'SEan
Here is a breakdown of the parts used for the complete Blue Led Project.
Gauges= 5 x 194 replacement leds
Shifter= 1 x 194 replacement led
Glove box= 1 x 194 replacement led
Trunk= 1 x 194 replacement led
Door lights= 2 x 194 replacement leds
Security= 1 x 5mm led
Window swt= 9 x 5mm leds
Dome= 3 x 5mm leds
Map= 3 x 5mm leds
Vanity= 4 x 5mm leds & 4 330 ohm resistors
Homelink= 1 x 5mm led
Keyring= 1 x 5mm led & 1 330 ohm resistor
Ashtray= 1 x 5mm led & 1 330 ohm resistor
Acc= 4 x 5mm led & 4 330 ohm resistors
2 x 3mm led & 2 330 ohm resistors
Hazard= 1 x 3mm led & 1 330 ohm resistor
Defroster= 2 x 3mm led & 2 330 ohm resistors
Dimmer= 1 x 3mm led & 1 330 ohm resistor
Cruise= 2 x 3mm led & 2 330 ohm resistors
Totals
194 leds= 10
5mm leds= 27
3mm leds= 8
330 ohm = 18
So what does all this cost?
194 leds= 10 @ 1.59 = 15.90 via superbright
5mm leds= 27 @ 1.02 = 27.54 via superbright
3mm leds= 8 @ 1.56 = 12.48 via eled.com
330ohm1/2w=18 @ .20 = 3.60 via radioshack
Total not including shipping = $59.52
Question is, can you afford not to do this?
Old Aug 12, 2003 | 07:49 PM
Thanks a bunch!!! Thats exactly what I wanted to know!!!
Old Aug 12, 2003 | 07:59 PM
z-dan's Avatar
Glad to help.
Old Aug 12, 2003 | 08:01 PM
Maxtank's Avatar
Araffio, it can be done, the fronts are same but the rears a little different, here my write-up...
Clicky
Old Aug 13, 2003 | 04:29 AM
SuperChris's Avatar
Infiniti 35 Double G's
"superbright"? Is that a site, store, or what? I've got some blue 194's already in my interior, but not nearly as bright as those in the photos. Where might one purchase some "superbright" blues?
Old Oct 24, 2003 | 10:16 PM
Max96LSU's Avatar
I just bought 10 leds (5 Blue and 5 White) from www.Superbrightleds.com
Here's the product # for the 194 bulb replacement...wled-w (194)... They ship extememly FAST!!! I plan on putting them in the gauge cluster tomorrowm I'll post some pics...
Old Oct 25, 2003 | 06:40 AM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showthread....ear+window+LED
does that thread help? if so should i add to the howto or if anyone does the rear to a 97+ wanna make a wirte up for me
there used to be one but i can't find it anymore
Old Oct 25, 2003 | 12:58 PM
R5a7B's Avatar
you dont have to use 12v leds in car? 5v are ok?
Old Oct 25, 2003 | 12:59 PM
araffio's Avatar
you can use any LED in the car, you just need a resistor.
-Tony
Old Oct 25, 2003 | 01:02 PM
R5a7B's Avatar
330 ohm?
890
Old Oct 25, 2003 | 01:15 PM
araffio's Avatar
I don't know, I used the resistors that came for free with the LEDs i bought on ebay.
I think 330ohm is correct though
-Tony
Old Oct 25, 2003 | 01:16 PM
R5a7B's Avatar
ok ill try them out, thanks
by the way, get those pics up man!
Kevlo911's Avatar
Kevlo for President
http://metku.net/index.html?sect=vie...calc/index_eng
Old Oct 25, 2003 | 04:30 PM
Maxtank's Avatar
97+ write-up
homeyclaus
Sep 3, 2015 06:15 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
spidgeon
Aug 18, 2015 05:46 AM
doobadoo
Aug 15, 2015 06:43 PM
