foglight problems
foglight problems
i installed my foglights for my 97 gxe 2 weeks ago. I was driving last night and found that my passenger fog light is out. i took it apart, and see a small crack in the connector located in the wiring (the plug from the wiring that goes into the foglight). i remember having that before the install, but everything seemed ok. anything else i should look at before panicing? if its the plug, where can i get a new one? (since its connected to the wiring). any suggestions?
Did you try to put some electrical tape on it? Also make sure that if the wire has a bare spot on it that it doesn't touch other metal parts of the foglight like the small bracket that holds the bulb in place. That can also cause the light to cut out.
Not really sure where you can get that piece from. You might want to try Courtsey Nissan for that.
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
