Swapped my Front Blues for a set of Illuminas
Old Sep 2, 2003 | 11:25 AM
  #41
njmaxseltd's Avatar
Originally Posted by goldmax
How much lowered are you with the HR? I would like to get a better ride, more control, etc. but using the stock SE tires and spring combination. Does HR make a progressive rate spring that keeps you at stock ride height? I'm trying to do what you describe but with stock SE wheels...smooth ride but very controlled.
Any idea if Illuminas/AGX combo would work well with stock springs?
Also, would you recommend Motivational mounts for the front? I need new mounts and don't want to get anything that will make the ride harsh.
H&R springs drop my car 1.8 inches up front and about 1.5 in the rear. You can run Tokico Illuminas all the way around. Motivational does not make front mounts, stick with OEM.
Old Sep 2, 2003 | 01:24 PM
  #42
goldmax's Avatar
Sounds good. Thanks for the feedback. Has anyone else tried the Illuminas with stock springs?
Old Sep 2, 2003 | 07:21 PM
  #43
mrmaxima97's Avatar
For those who are interested, check out my experience while at Tom's.
My Proline Experience
Thanks again Tom for everything. I am not sure yet what I have planned for the rest of my suspension. The Maxspeed/AGX combo isn't that bad on stock rims, but on my 18's forget it. I am either going to go back to stock (for the ride) or make the final plunge and mirror Tom's.
Rides like a dream!!!!
Old Sep 2, 2003 | 09:59 PM
  #44
DR0832's Avatar
Are you serious the H&R drop your car 1.8 front and 1.5 rear? Hows that possible? I thought they gave a 1.4 front and 1.3 rear drop?
Old Sep 3, 2003 | 06:58 AM
  #45
Bluebird's Avatar
I am Roid Rage
Originally Posted by ny96max
your nuts...
Ant
The use of your and you're has never been so critical.
Old Sep 3, 2003 | 07:08 AM
  #46
njmaxseltd's Avatar
My Autotragic loaded Cali Spec SE-L is heavier then most Max's and always drops more when I lower it.
Finkle
Sep 27, 2015 09:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
soon2ownmax
Aug 13, 2015 02:19 PM
Balkins
Aug 12, 2015 06:39 AM
