Ignition Switch problem??
Old Aug 12, 2003 | 06:23 PM
totalpackage's Avatar
Having a problem with the ignition switch. On a very hot day when I turn the ignition I get power to the car but the car doesn't start. After fiddling around with the ignition switch it will eventually start. But somedays it takes longer than others to start the car. Is this a problem with the ignition switch or could it be something else? Thanks for your help!!!
Old Aug 12, 2003 | 06:29 PM
maximaseefu's Avatar
i have the exact same problem with mine....is yours 5 speed?
Old Aug 12, 2003 | 06:30 PM
nope. unfortunately its automatic. have u heard any fixes on this problem.
Old Aug 12, 2003 | 06:50 PM
no, i have asked a few times but never get any response.
Old Aug 12, 2003 | 07:26 PM
Maximum96's Avatar
i have the same problem, i think its a plastic piece right behind the key hole but never checked, a mechanic told me that..
Old Aug 12, 2003 | 07:27 PM
z-dan's Avatar
Try this, have someone hold the key at the cranking position and bang the starer with a small hammer or somthing. if it starts, you have a starter problem. i had the same problem a while after i changed the starter, so i took it to a michanic and it was the ignition switch. he fixed it for $90 including labor.
Old Aug 12, 2003 | 10:41 PM
95CustomMaxima's Avatar
My '95 Se 5spd had the same problem. I took it to Nissan, and they replaced the ignition switch for 75 dollars(part and Labor).
Old Aug 13, 2003 | 03:48 PM
Kevlo911's Avatar
Kevlo for President
I had hte prob, fixed it for 33$ shipped, buy a new ignition switch from www.newnissanparts.com or local dealer(but online seems better to me) VERY VERY easy to replace.
http://forums.maxima.org/showthread....gnition+switch
Old Aug 13, 2003 | 05:40 PM
Thks gang for your reponses. I hope its the ignition switch and not the starter. What repair manual do you guys recommend?
mikeg75
Nov 30, 2015 05:12 PM
rnb754
Sep 14, 2015 11:39 PM
Maxie40
Sep 14, 2015 11:28 AM
