Cosmetic questions...
Old Aug 13, 2003 | 05:43 PM
ChanMan96SE's Avatar
What's up guys, I have a few quick questions that I hope have simple answers... Gimme a shout if you can give some advice, I just got the car...
- I want to peel the badges off the back of my '96 SE, is it as easy as taking them off and cleaning the area with bug/tar remover then wax?
- Display on stock BOSE head unit out. I guess it's common, is there any remedy?
- Want to get clear corners and grille mesh: Suggestions?
Thanks, I'll really appreciate any input.
It's my first (and definitely not last) Maxima, I'm lovin the car
Old Aug 13, 2003 | 06:24 PM
Taken2DaMax's Avatar
1. The hamburger on the back of the car is easy to take off. All you need is fishing line or floss. Take the FL and carefully place it behind the symbol, using a side to side motion.
And yeah it is easy to remove the glue on the car with that stuff(i used a wax remover), it just takes a lot of elbow grease.
2 dunno
3 You can get clear corners easiest and cheapest on ebay. I suggest diamond cut because they are more eye catching.
Mesh grill can also be purchased on ebay but don't waste your time with that. You can get some good mesh grill at you're local Home Depot or hardware store(i did and it looks the same as others). To install, i used a fellow members page to do my. He didn't even know that his page helped many members.
Go to the "member pages" and go to the 1997 maximas. His page should be under "Evolving Digimax", it probably the second one. When you are on his page go to the second page and there should be instruction on how to do it yourself. It's easier than you think.
wingsfan24
Aug 15, 2015 07:35 PM
DNA21
Aug 30, 2001 05:10 AM
hodgeee
Jun 12, 2001 04:38 PM
hoey
Apr 4, 2001 01:09 AM
