HIDs keep burning my wire harnesses
Old Aug 13, 2003 | 06:35 PM
o NJ Maxima o's Avatar
Every 3 months I've been changing my wire harnesses for the past year and a half because they can't handle the extra heat the HID replacements dish out.
Anyone know where I can get a wire harness that will hold the HIDs without melting like this plastic piece of garbage that Nissan hooked the Max's up with?
Old Aug 13, 2003 | 06:39 PM
97GLES's Avatar
Re: HIDs keep burning my wire harnesses
your the first person that i heard that has this problem. what kind of hid kit are you using?
Old Aug 13, 2003 | 06:44 PM
just regular ones that you get at any performance shop.... 1004s? I've tried different brands and they've all yielded the same result. When I went to Nissan the mechanic said to me "you got the HIDs, eh?" and explained that they burn up the plastic harnesses that nissan put in the Max's. Do you know of anything I can do besides replacing the harnesses?
Old Aug 13, 2003 | 06:58 PM
97GLES's Avatar
i think you got halogen bulbs that are 75w or more, not hids.
hids use a balast to power the bulb.
Old Aug 13, 2003 | 07:09 PM
so what should i do?
Old Aug 13, 2003 | 07:12 PM
99MAXSE-L's Avatar
wait....do u have the REAL hids, or just bulbs?
how abotu this....how much did u pay for these bulbs/hids?
Old Aug 13, 2003 | 08:20 PM
Spectre's Avatar
I just bought HIDs and they came in the mail (Phillips 8000k K2) problem is the left side of my connector is burnt and messed up and won't work with the HID. How much would cost to repair this? Do I need a whole wire harness or just the connector cause it still sorta works with the normal cool blue bulbs, only when you move it around tho but I'm not about to that when the HIDs are hooked up to it. Thanks in advance.
Old Aug 13, 2003 | 08:30 PM
Spectre's Avatar
Oh and how much does all this cost?
Old Aug 13, 2003 | 08:46 PM
geo1317's Avatar
i think hes talking about the HID Look alike halogen bulbs. Goto suvlights.com they have some nice wiring harneses. get the 9004.
Old Aug 13, 2003 | 09:55 PM
I'm having that same problem... when you get sick of it there are only two ways to repair it..
1. take the wire harness out and put in wire slides over the ground wire part of the harness.. that's the one that always burns out on me... then it should last another month...
after that..
2. replace the harness
Old Aug 13, 2003 | 10:14 PM
FAQ, eh?
Old Aug 13, 2003 | 10:23 PM
ch13f's Avatar
^ You dont have actual HIDs, just really high wattage halogen bulbs. HIDs actually use 35watts or so, basically.. they won't burn out the wire harness. A conversion kit will cost you like 300-600$
Old Aug 13, 2003 | 11:03 PM
Nismotic's Avatar
Always sunny in philly
nokya upgraded harnesses will do the trick. southwestautoparts has them ...a pair for ten bucks (i think). just get a real HID kit.
Old Aug 13, 2003 | 11:17 PM
Spectre's Avatar
I have a $600 HID which I just got today, I'm damn ****ed cause I wasn't able to use cause my cheap bulbs that I was going to replace today messed up my harness. Grrrrr
Old Aug 14, 2003 | 12:35 PM
Ant96GLE's Avatar
I'm guessing you have bulbs that look like HID. The reason they look like it is because of the extra wattage the bulbs require. However your stock harnesses cannot handle the extra wattage. The previous owner of my Max did this and melted the harnesses. I got a pair of 9004 harnesses from a local auto parts store for $5 bucks each and put them on and I havent had a problem. There are upgrades for stronger harnesses that handle more wattage but your looking at about $50 bucks last time I checked. My advice, unless you really like those bulbs, get rid of them and you'll be getting rid of the headache. You'll be burning harnesses all the time.
Anthony
Old Aug 14, 2003 | 12:47 PM
njmaxseltd's Avatar
Take those crappy blue coated high wattage rice bulbs out and use the correct type & wattage bulb in your headlights.
It's pretty simple, really.
mclasser
22
Nov 12, 2020 01:58 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
zmcneely13
Sep 26, 2015 02:26 PM
