how to get upper brake lines off the car?
Old Aug 14, 2003 | 12:03 PM
costcowholesale's Avatar
I took the clip off that sepeate the steel line & rubber ones and then I turned the 10mm bolt with a wrnech... it was so hard to turn i ended up stripping half the bolt and then I tried vice grip to hold the bottom and turn it... still nothing
I got the bottom connectors out really quick but the top lines is stuck
I'll take some pics soon
Old Aug 14, 2003 | 12:13 PM
Kevin Wong's Avatar
I believe you need a set of Vise-Grips to hold the bottom half. I learned this after I screwed my up doing my first brake job with the Wilwoods.
Old Aug 14, 2003 | 12:20 PM
oh **** ... I went to local store to get a vice grip after that bolt didn't go anywhere, put the grip on the bottom and turned and started stripping it what can I do :/
Old Aug 14, 2003 | 12:23 PM
xHypex's Avatar
You stripped it because you needed to use a flare nut wrench instead of a normal wrench. Flare nut wrenches are mentioned on almost every brake line thread
Now that you've stripped it a vise is the only way you're going to get it off.
-hype
Old Aug 14, 2003 | 12:25 PM
-hype
it is not totally stripped.. only half the bolt is stripped I'll just turn it around with the vice grip and find a flare nut wrench (got a pic of those?)
Old Aug 14, 2003 | 12:34 PM
xHypex's Avatar
http://test.maxima.org/showthread.ph...are+nut+wrench
http://www.sears.com/sr/product/summ...id=00944177000
Old Aug 14, 2003 | 12:45 PM
njmaxseltd's Avatar
Lakersallday24
Jun 16, 2019 01:35 AM
tcb_02_max
Sep 11, 2015 12:23 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
