Cleaned my TB and now..........
Old Aug 14, 2003 | 05:36 PM
Maxima 504's Avatar
so i decided to clean my throttle body yesterday. and now every time i start up my max the rpms jump to 2K and sit there for a while or until i press the gas then they drop down to 1K or 900. it never used to do this before. has anyone experienced this problem or know what can be done to fix this. any info would be appreciated. thanks.
Old Aug 14, 2003 | 05:45 PM
hacim105's Avatar
Re: Cleaned my TB and now..........
I have the same problem as to what to do about it I don't know. I don't think it matters though.
Old Aug 14, 2003 | 08:14 PM
brizsblackmax's Avatar
you motors aluminum for it to idle high after start up without warmin gup first will slowly degrade the seals and bearings and engine componants that require oil to be pumped between them being that a cold car has thinker oil and, has not been circulated yet so... etc.. do the math
Old Aug 14, 2003 | 09:22 PM
Maxima 504's Avatar
say what?
Old Aug 14, 2003 | 09:29 PM
nismos14's Avatar
§è~® f®ÈÄk
lolz hes right to an extent
Old Aug 14, 2003 | 10:56 PM
Maxima 504's Avatar
Well i just went and too a ride and when i got home i put it in park and the engine revs to 2K rpm. Before i cleaned the TB it did not do this... it was always lower. can anyone explain this to me????
Old Aug 15, 2003 | 05:04 AM
Gates's Avatar
he means its bad for the car to idle high
say what?
Old Aug 15, 2003 | 05:35 AM
deezo's Avatar
How did you clean the Throttlebody? Did you remove it? Make sure the butterfly valve is closing to its maximum position.
Old Aug 15, 2003 | 06:47 AM
njmaxseltd's Avatar
Best incohearent(sp?) run on sentance ever!
A 2K start is a little high. Sometimes the ECU will adjust to your freshly cleaned TB. Sometimes it can't. You might have to clean your IACV as well. Or you may have to tweak down your high idle screw on the fast idle plunger.
A Haynes manual is your friend.
Old Aug 15, 2003 | 07:49 AM
PolarisGT's Avatar
Any instructions on IACV cleaning?
I think my max also deserves IACV cleanup but there is little information on the web.
Old Aug 15, 2003 | 08:29 AM
JdawgX's Avatar
Clean your IACV and you should be fine.
Old Aug 15, 2003 | 10:23 AM
TylerBorg's Avatar
Somebody care to elaborate on the cleaning of the IACV
Old Aug 15, 2003 | 11:00 AM
Maxima 504's Avatar
well when i cleaned my TB, i just took off my midpipe ad sprayed the half the cleaner in there.... and all this dirt came out and then i ran the engine and sprayesd the rest of the can in..... just like the instructions on the can say...... what should my max idle in in park?
Old Aug 16, 2003 | 07:27 PM
KsuMax's Avatar
Cheesing away...
I also would like to know this.
You should have sprayed the cleaner in and with a rag, you should have wiped all the crap out.
Old Aug 16, 2003 | 09:44 PM
cefiro a32's Avatar
best way to clean tb is to first spray a little bit of cleaner on butterfly plate and tb. Let it sit for a minute and wipe with a towel. next turn car on and spray cleaner for 10 sec and wait ten seconds. repeat until can is finished. If engine begins to choke wait longer between sprays.
Old Aug 16, 2003 | 09:55 PM
maxhead's Avatar
I did the same way but car wouldn't run. I guess the car thought it was a big leak after the MAF. After it stalled, I tried a few more times...same thing. I just sprayed the rest of the bottle in, cleaned it up with a rag, started it up & it's been fine ever since.
Old Aug 16, 2003 | 10:00 PM
97GLE's Avatar
Did you disconect the MAFS? Have a Check Engine Light?
Maybe you should reset the ECU, couldn't hurt.
Old Aug 16, 2003 | 11:20 PM
maximaseefu's Avatar
you have to put everything back together and just not tighten the clamp around tb, stick the straw thing from tb cleaner into the gap to spray it in and engine will stay running.
Old Aug 17, 2003 | 03:30 AM
sanjosemaxima's Avatar
Sleeps with his maxima!
im a little cunfused, why do you spray it with the engine running? wouldn't it go into the engine, or is that the point?
thanks
Old Aug 17, 2003 | 09:26 PM
nismology's Avatar
When I cleaned out the throttle body, I removed it. Should I have purchased a new TB gasket because now the car idles too high??
Old Aug 17, 2003 | 10:21 PM
indigomax's Avatar
look guys....i have cleaned my TB a lot of times...and i will say this. After you clean your IAC, bla bla bla, TB you must adjust again the IDLE this is the most important thing to do after all this good/hard job...you should know how adjust it...is simple just adjust the screw that is located on top of the IAC valve...
Old Aug 17, 2003 | 11:28 PM
yeah, but how do you clean the iac?
Old Aug 18, 2003 | 11:49 AM
indigomax's Avatar
its easy...just disconnect the iac controls... then remove the 2 iac valve attaching screws adn withdraw the valve from the iac housing.
Old Aug 18, 2003 | 12:22 PM
maxhead's Avatar
Ohhh, that makes sense. I never thought of that. The way I did it worked pretty well but I guess I didn't get the TB cleaner into the engine. I'll do it that way next time. Thanks for the tip.
Old Aug 18, 2003 | 12:32 PM
FLO_BOY's Avatar
engine running high is normal after a TB cleaning...your ECU will
adjust itself accordingly...
you do this with the car running so that you can get the cleaning
solution deeper into the intake and clean some more...
I *believe* that you can simply remove the IACV and spray it liberally
with the cleaner...let it dry, and then re-install.
FLO_BOY
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
