"SERVICE ENGINE SOON" Light Is ON!
Old Aug 16, 2003 | 12:24 PM
DoGGy
guys I just got my max 2 days ago and it only has 24,102 miles on it. today i was driving and suddenly the "SERVINCE ENGINE SOON" light came on. Im so upset and stressed now, what is up with the car? is it something big? wth is wrong with my max.
Old Aug 16, 2003 | 12:28 PM
DoGGy
ANYONE pleasE? i just pay **** load for this car, wth is wrong?
Old Aug 16, 2003 | 12:41 PM
speedemn's Avatar
Re: "SERVICE ENGINE SOON" Light Is ON!
Check the FAQ on how to read check engine light codes. There's a detailed write-up on it in there.
Good luck!
Old Aug 16, 2003 | 02:09 PM
DoGGy
i just checked the faq's and did what it said. i got 4 long flashes and then 10 really fast ones, but the site says that the code is wrong :\
Old Aug 16, 2003 | 02:19 PM
Kevlo911's Avatar
Kevlo for President
reset ecu and see if it comes back
Old Aug 16, 2003 | 02:21 PM
DoGGy
mate, i did the test again and this time it gave me 05 and 05. i went back to faqs and entered the code, it tells me that no failure was detected, if so why is the light on? should i reset it?
Old Aug 16, 2003 | 03:36 PM
speedemn's Avatar
Yeah reset ECU (the screw turning way) and see if the code comes back.
Old Aug 16, 2003 | 03:55 PM
Kevlo911's Avatar
Kevlo for President
yes reset and if it comes back, report to us
Old Aug 16, 2003 | 10:09 PM
outsider's Avatar
same problem here but i think mine have something to do with the 60k maintance. i heard that why my light is on at 56k. is it true?
Old Aug 17, 2003 | 06:37 AM
speedemn's Avatar
No, you will not get a CEL if you miss a tune-up. However the CEL means that something is malfunctioning. Pull the codes first, and then reset it and see if it comes back.
Old Aug 17, 2003 | 05:38 PM
DoGGy
well, the light has been off since last time i pulled the code, the light has been off for 24 hours! at least thats a relief. Could anyone possibly explain why it went on in 1st place ? is it because my gas tank is 20% full or could it be the 25k mile maintaince ? anything at all?
Old Aug 17, 2003 | 05:54 PM
speedemn's Avatar
What changed in the last little while? New plugs, something unplugged and plugged back in?
Old Aug 17, 2003 | 06:58 PM
outsider's Avatar
how do u reset the ecu?
Old Aug 17, 2003 | 07:25 PM
aceptedeclectic's Avatar
Try reading the FAQ I believe it tells you.
Old Aug 17, 2003 | 10:42 PM
DoGGy
NOTHING changed, i checked the code once, then checked it again 20 min after. thats all i did, after the 2nd time i checked the code, i went back to house and decided not to think about the car anymore. so 2-3 hours after, i went back and turned it on. the light was off and it has been off ever since. it has been off for 33 hours now
kjlouis
Nov 24, 2018 06:09 AM
rbaker100
Aug 28, 2015 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
