squealing/groaning noise from clutch pedal inside car???& GOD D A M CHATTER!! & more
Old Aug 17, 2003 | 12:13 AM
RI-Max's Avatar
1. ok guys i have 153,00 miles on my maxima 5 speed. everytime i press on the clutch pedal or release it makes a squealing/groaning noise from the pedal i sprayed some lube (silice/red gease)on the spring & the lil rod that goes into the fire wall.( doesn't have 2 be in gear does it with the car on or off, release or presssued makes noise) but no luck. any ideas?????
2. i have a ACT street clutch. with 20,000 on the clutch. i still get the really bad chatter.(getting tired of it). BTW how long do these clutch last anyways????????
3. i have another problem
it sounds like i have lil birds chirping in my trans when its chattering (launch normaly) any idea whats this means???? still grabs nice tho chirps 3rd every time .
thanx hopfully some can help me.
jeff
ps: still have a factory flywheel. did get it resurfaced buy napa. (when install the clutch) i got the ACT clutch kit. the only thing i didn't replace was the pilot bearing.......
Old Aug 17, 2003 | 02:17 AM
Nismo's Avatar
release bearing, did you replace that?
Old Aug 17, 2003 | 07:45 AM
RI-Max's Avatar
aka throw out bearing........yesss
Old Aug 17, 2003 | 08:57 PM
RI-Max's Avatar
bump!!
Old Aug 17, 2003 | 10:32 PM
ThurzNite's Avatar
20,000mi on my act clutch and stock resurfaced flywheel. still chattering, but not as much as before. engagements suck...not grabby now.
Jae
Old Aug 18, 2003 | 07:56 AM
seegarman's Avatar
I had a similar "noise". I replaced the clutch master and slave cylinders.
Old Aug 18, 2003 | 09:57 AM
RI-Max's Avatar
ya but the the noise comes and goes. could it be the master/slave but i hear it from the pedal.
Old Aug 18, 2003 | 10:43 AM
matty's Avatar
get underneath by your pedal and move it up and down with your hand and see where the noise is comeing from...seems like the rod going into the master cylinder is not greased up enough..take some lithium grease and do that rod up...if its still there spray some WD up in there where you hear it...I used to have it, 15 min later not one peep at all
as for the chatter...Me too...thats the price for performance
-matt
Old Aug 18, 2003 | 10:50 AM
Jeff92se's Avatar
I'm needing a caw
Check your motor mounts everyone for clutch chatter.
Old Aug 18, 2003 | 10:56 AM
matty's Avatar
I did 3 out of 4 of my motor mounts with poly...Im about to drop out the third (pass side top mount) and fill it with poly
-matt
Old Aug 18, 2003 | 02:22 PM
RI-Max's Avatar
i got place racing mounts and a new trans motor.mounts still all good..
i got 2 try and grease the rod again
thanx jeff
Lakersallday24
Jun 16, 2019 01:35 AM
egali045
Aug 16, 2015 01:19 PM
maxima-junky
Aug 13, 2015 09:59 AM
ef9
Aug 13, 2015 01:19 AM
MikesChevelle
Aug 10, 2015 10:53 AM
