Exhaust leak check
Old Aug 19, 2003 | 09:45 AM
Zirafa's Avatar
Exhaust leak check
What is the best way to check for exhaust leaks, the ones around the joints/bolts in particular? Any tips, tricks, etc.?
Old Aug 19, 2003 | 10:02 AM
ZuMBLe's Avatar
Re: Exhaust leak check
I saw a muffler guy cover up the exhaust pipe with his bare hands to look for leaks. Of course.. you may want to use something other than your bare hands. =P
Old Aug 19, 2003 | 10:19 AM
sleepermaxima's Avatar
Re: Re: Exhaust leak check
Did you also see this guy's hands? Be careful.
Two other things you can do,
1. with the car running, get your ear within a couple feet from the exhaust line. You should hear a tick-tick or a puff-puff depending on how far the leak is from the manifold.
2. examine the line visually, look for black spots or streaks. This is residue from the exhaust seeping out of the hole. You may need a mirror and a light to see the top side of the piping though.
D
Old Aug 19, 2003 | 10:33 AM
ZuMBLe's Avatar
Re: Re: Re: Exhaust leak check
The guy wasn't even phased! I'm sure his hand is one big callus though. No glove. He must have had his hand on top of the hole for a good 30 seconds. Definitely long enough to burn normal people.
ZuM
1. with the car running, get you ear within a couple feet from the exhaust line. You should hear a tick-tick or a puff-puff depending on how far away from the manifold you are.
2. examine the line visually, look for back spots or streaks. This is residue from the exhaust seeping out of the hole. You may need a mirror and a light to see the top side of the piping though.
D
Old Aug 19, 2003 | 10:57 AM
Zirafa's Avatar
Thanks. I am in FL and don't expect it to be rusted or anything - I'm suspecting a tiny tiny leak where the y-pipe meets the exhaust manifold. Perhaps one of the bolts is broken or loose or something...
Old Aug 19, 2003 | 11:44 AM
ZuMBLe's Avatar
In that case. Use a small plastic tube like fishtank air hose and put one end to your ear and the other end to the area you think may be leaking.
lowpost99
Oct 26, 2025 06:53 PM
kmitchel
Oct 30, 2015 10:12 AM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
