GC tokico blues
Old Aug 20, 2003 | 06:49 PM
maxmobile's Avatar
GC tokico blues
After a long search on springs, progress, sprints, H&R, and Eibachs, I realized the drop wouldnt be low enough. So I threw caution to the wind and went with GC's Got them monday am and installed the ground controls that night.. I also got Tokico blues for them .. right now I have them at the lowest setting which is just about right... the ride wasnt as bad as I thought... and it took 3hrs for the install... I guess it helps to have an air compressor...
http://www.cardomain.com/member_page...=260981&page=2
Old Aug 20, 2003 | 08:00 PM
95CustomMaxima's Avatar
Looks excellent, car is immaculate. How low is that drop? 3 inches? How has the ride been so far, bumpy? Any Noises? Also do you have any tips/suggestions for the install og the GC's + Struts?
-Nick
Old Aug 20, 2003 | 09:45 PM
97blackSE's Avatar
Wow, Nice Honda Accord...
Old Aug 20, 2003 | 10:01 PM
J 9MAX9's Avatar
looks good, i have the tokico's, just drove to florida and back (from ct), and i have no problems... Good photography work on the site too...
Old Aug 20, 2003 | 10:12 PM
EteRnity059's Avatar
Boosted?....
I had tokico blues in my rears and they were gone pretty much after 3-4 months with my eibachs. The front struts are fine and I still have them on my car. I swapped the back with KYB AGX's and they are wonderful. Completely night and day difference. Good luck with the rears and if they blow, get AGX's
Old Aug 20, 2003 | 10:13 PM
97blackSE's Avatar
you are from CT, J 9Max9?
Old Aug 20, 2003 | 10:56 PM
Dev's Avatar
Dev
Re: GC tokico blues
http://www.cardomain.com/member_page...981&page=2
sweet looking ride dude
i don't think the blues will last too long...the rears do tend to blow quickly
im currently on ground control and stock shocks for about 5 months...on a 1.5" drop
are your making any noises?
Old Aug 21, 2003 | 09:10 AM
Dev-
Are you having any problems with your GC's? Hows the ride been? You asked if he is having noises. Are you experiencing noises from the GC's? If so what kind of noises?
-Nick
Old Aug 21, 2003 | 11:28 AM
maximashorniest's Avatar
Re: GC tokico blues
I dont know about u but i have the same set up and i think it rights like crap... hows the ride? stiff soft?? i bottom out alot and its not even that low.. do u think that they're uneven or something.. let me know.. THANK YOU!! somebody anybody..opinions>>
Old Aug 21, 2003 | 02:24 PM
maxmobile's Avatar
I like the ride, I was expecting worse after riding my Cuz's ride (the accord on the page). I dont have any noises comming from the GC's only the mud guards scraping from speed bumps once in awhile. It does get a bit bouncy at times (the struts can be stiffer) but I can live with it for now. As for the installation the only thing that really slowed me down was compressing the springs which took some time and getting the O-rings on the front when prepping the GC's that was a real pain. The rest of the setup was straight forward. I did take off my seats to get to the back struts only to find the access in the trunk (it was 1am when I was doing this) I have them set at its lowest settings. But if the shocks fail, will the KYB's fit, I tried searching this before with the different GC model and shock setup and thought that they have a different setup.. but I dont know what the differences are...
Old Aug 21, 2003 | 03:04 PM
ThurzNite's Avatar
What did you use air tools on? I can't think of anything that would require them. Or maybe u don't have the right tools for the job and cut corners w/air tools?
What did you mean by "I realized the drop wouldnt be low enough"?
Jae
Old Aug 21, 2003 | 04:25 PM
maxmobile's Avatar
Air tools just help with removing those nasty bolts and compressing the spring basically cutting corners... and as for the drop comment I saw some max's with eibachs, and progress setup and it still looks too high and so I didnt want to take any chances with the 2" springs... also it gives the option to raise them for the winter... just gotta grease them up before so that they dont sieze...
Old Aug 21, 2003 | 04:42 PM
ThurzNite's Avatar
Did you get stock springrates w/the GC? Or go custom?
Jae
Old Aug 21, 2003 | 09:32 PM
J 9MAX9's Avatar
yea, i'm from watertown, (waterbury area), i try to go to the pike as much as i can...
Old Aug 21, 2003 | 10:23 PM
Dev's Avatar
Dev
Originally posted by 95CustomMaxima
Dev-
-Nick
i have eliminated the clunking noises by putting goodyear heater hose between the sleeves and shock/struts..to avoid the metal/metal contact.
where i do get noises at times is going VERY slow and turning the wheel...it has a squeeking sound...and after a few turns it'll go away...
so its basically just when i start the car and take my first couple turns...then it goes away.
Thurznite, you do need air tools for this job...the strut bolts on the bottom are on very tight, possibly rusted and seized on. also takes off the lug nuts in a couple seconds.
Maximashorniest, i don't find the ride too bad...its very similar to my friends with eibach/agx. my car actually rides a bit softer, but does not absorb bumps as well (bounces) more than his (which dampens more).
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
