Vaccum leak help!!!
Old Aug 22, 2003 | 08:09 PM
NISMOPower's Avatar
Vaccum leak help!!!
I have a vaccum leak somewhere near my throtle body I believe. Don't know what to do or where to start? Any methods or something that will help?
Chris
Old Aug 22, 2003 | 08:12 PM
njmaxseltd's Avatar
What makes you think you have a leak? :curious:
Old Aug 22, 2003 | 10:36 PM
NISMOPower's Avatar
I was fixing a leak in rear timing cover and that required to take the plenym intake and valve covers off. So when i started the car, the engine wasn't running smooth at all. Idle would fluctuate. Also I hear a hissing sound near my throttle body. Also I have a code 13-2 - MAP/BARO SW Solenoid/Valve but Matthel/Turbo95Max told me not to worry about that....So what next????
Chris
Old Aug 23, 2003 | 04:49 AM
njmaxseltd's Avatar
OK you have a leak. Check with an auto parts place. There's a spray you can use that will help you locate it.
Old Aug 23, 2003 | 10:58 AM
Dave Holmes's Avatar
I've been told that starting fluid will work (makes idle higher when sprayed near a leak), but worry about the safety issue of spraying ether near anything hot. TB cleaner sprayed near a leak will cause the idle to drop.
A mechanics stethoscope can help you pinpoint it by sound since you said you can hear it.
Dave
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
followthadollar
Sep 17, 2015 06:31 PM
