Does 02 sensor control it all?
Old Aug 22, 2003 | 12:19 PM
reliable95's Avatar
In reading past posts, it looks like the 02 sensor could be my problem. How much does it control engine idle/running.
Today my car took a full minute after a warm (not hot)start to idle normal (I had to keep rpm's up at 2,000 to 2,500 to avoid stall)
Does 02 sensor have this much control?
Old Aug 22, 2003 | 12:21 PM
mzmtg's Avatar
Minister of Silly Walks
No, that does not sound like an O2 sensor problem.
Old Aug 22, 2003 | 12:58 PM
multiplexor's Avatar
IACV maybe?
Old Aug 22, 2003 | 01:12 PM
ivelweyz
if you don't have a code it's not it...
Old Aug 23, 2003 | 10:01 AM
reliable95's Avatar
Thanks,
I will keep on looking.
Am doing to clean the throttle body today. I hope that helps.
Old Aug 23, 2003 | 10:12 AM
meccanoble's Avatar
Sports Button FTW
02 sensor makes car run better but your problem sounds beyond that. I always had a good idle. One thing i unconciously realized after changing my 02 sensor was that i need less gas to do everything. Before i could roll out with no gas but would have to keep playing with clutch and rpm's, like move a little and be about to stall and floor clutch in then slightly let it out so i can move a little more and when i finally have momentum i can just let go of clutch. NOw i can do it a lot easier...
signs for new 02 sensor...
-a lot of gas needed to get out of first gear
-nasty first gear
-bad gas mileage
-code (front is 03 03) and thats what i got
Old Aug 23, 2003 | 11:50 AM
ivelweyz
0503 is also for the front, front left I believe...
bbsitum
Sep 6, 2019 07:31 PM
Starrider
Dec 18, 2015 04:43 AM
EdRomo86
Sep 12, 2015 07:49 PM
