Braking Vibration
Old Aug 26, 2003 | 08:45 PM
Just the Max's Avatar
Braking Vibration
When I brake hard I get a hard vibration throughout the car. I have 41K on my SE. Are 4th Generations notorious for warping rotors?
What do you recommend?
JR
Old Aug 26, 2003 | 10:36 PM
iansw's Avatar
Yes.
Get them resurfaced or replace them with Brembos.
Old Aug 26, 2003 | 11:31 PM
sryth's Avatar
Autozone's cheapest rotors ($29/pop) work like a charm!
Old Aug 27, 2003 | 12:55 AM
Cool J's Avatar
that is the abs that is working. if your car doesnt have abs then something else is wrong but i am pretty sure that is the abs. when i brake hard in my 2.5 tl it does the same thing.
In order for you to realise the benefits, you need to know how to drive with ABS. In an emergency, most drivers will jam on the brakes as hard as possible. With ABS, this is the right thing to do but when the ABS starts working there may be a vibration or shuddering through the car and the brake pedal may pulsate. Some drivers think that something is drastically wrong and take their foot off the brake. This is the wrong thing to do - for ABS to work properly your foot must remain firmly on the brake pedal.
here is the link about abs
http://www.vicroads.vic.gov.au/vrne/...Road+Safety%5D
Old Aug 27, 2003 | 01:53 AM
Matt_NZ's Avatar
Mine's just started doing this as well. Don't think it's the ABS though as it's only just started doing it, and I haven't changed the way I brake.
I only just got them re-surfaced in Feb. I wouldn't have thought they would need to be done again this soon? I haven't been braking hard or riding the brakes either
Old Aug 28, 2003 | 08:59 AM
sryth's Avatar
Stock rotors warp. Get new ones.
Old Aug 28, 2003 | 09:15 AM
Jatan's Avatar
Which ones don't warp easily?
Old Aug 29, 2003 | 01:03 PM
sryth's Avatar
Autozone's cheapest...$29/piece.
Old Aug 29, 2003 | 01:24 PM
Iron Scimitar's Avatar
Tha Snatcher
You get what you pay for...be careful.
Old Aug 29, 2003 | 01:41 PM
joew's Avatar
autozone is not good? just curious.
Old Aug 29, 2003 | 03:06 PM
sryth's Avatar
It's true...you get what you pay for. But you can also pay too much for stuff you don't need. I've been running with them for 3 years with no problems whatsoever.
Old Sep 1, 2003 | 04:08 PM
SXN's Avatar
SXN
JR
Happened to my last car... heavy braking causes the car to vibrate and make a weird noise? kinda deep and heavy sound, like loud tires on moving pavement? you have warped rotors which is no good, the stock ones dont last forever with heavy braking, a lot of stop and go, racing or whatever. get some new ones!
Old Sep 2, 2003 | 09:47 AM
joew's Avatar
Good info. thanks.
what is wraped rotor?
Old Sep 9, 2003 | 08:59 PM
SXN's Avatar
SXN
means the braking rotor (grabbed by the pads and calipers) is no longer true, and perfectly flat. kinda wobbles side to side, lowers braking peformance, CAN make the car wobble, make a deep weird noise
Old Sep 9, 2003 | 11:16 PM
ThurzNite's Avatar
like crossdrilled rotors? Hehe. Aggresive driving might warrant slotted rotors, but regular driving won't need anything but those autozone rotors.
Check out the group deal forum for aftermarket rotors. There's some Brembo Zinc blanks going for $40something for a pair.
Jae
Old Sep 10, 2003 | 07:21 PM
SXN's Avatar
SXN
whats to say we dont drive aggresively? lol, im sure plenty of org members do
Old Sep 13, 2003 | 12:11 AM
sryth's Avatar
I definitely drive very aggressively...and the Autozone cheapies always slow me down in time.
Old Sep 13, 2003 | 01:06 AM
SXN's Avatar
SXN
and the maxima being a curvey lady of a car... stopping good is important. i opted for some nicer rotors than just solid plain rotors, but its not really necessary
Old Sep 29, 2003 | 09:15 PM
DoGGy
i got same problem too, specially on freeway. when im going lets say 65-70 and and press brake pedal on a medium force, i feel this vibration going throught the entire car. r u sure its abs?
Old Sep 29, 2003 | 09:19 PM
SXN's Avatar
SXN
no, cuz my car with that problem was not ABS...heavy braking (abs or not) warped the braking rotors over time, develops that wobble
Old Sep 30, 2003 | 01:04 PM
Jatan's Avatar
I know my rotors are warped Need a job
Old Oct 1, 2003 | 08:06 AM
DoGGy
so what should i do
Old Oct 1, 2003 | 01:07 PM
ran's Avatar
ran
Hi Guys
My 99 Maxima GLE makes this noise even when brakes are not applied, especialy noticable on smooth pavement when road noise is minimal. I was even thinking about CV joints. Can you hear warped rotors without brakes applied?
Old Oct 1, 2003 | 01:49 PM
Jatan's Avatar
You can't hear warped rotors.
Get under your car and look at the boots for the CV joints. If they're ripped, then you need new ones... Go here: http://www.motorvate.ca/mvp.php/400
Old Oct 1, 2003 | 03:49 PM
SXN's Avatar
SXN
Originally Posted by ran
Hi Guys
brakes not applied making noise....kinda sounds like the squeeler pads on the brakes, they can kinda make a little squeeling noise/jingling sound. tells you that your brake pads are worn out, how old are you pads?
Old Oct 1, 2003 | 06:08 PM
ran's Avatar
ran
Pads are new and the noise is not squiling. It sounds more like bumpy tire, but I check tires already.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
