Help! Odd hestitation problem
Old Sep 6, 2003 | 02:21 PM
multiplexor's Avatar
Hey guys,
On my way back from a trip to Ottawa, I noticed on the highway that my car would lose power gain power lose it, come back...
Yet I was holding the gas very steady!
I cleaned my TB and my IACV (IACV not cleaned toroughly though)
KS changed... what could be the problem?
Does the IACV affect my power at those speeds? I was at ~3.5k in 5th.
could it be a bad coil pack?
If so, what's the proper resistance of a coil pack?
Thanks guys.
Old Sep 6, 2003 | 07:51 PM
bump hehe
Old Sep 6, 2003 | 08:19 PM
Dave Holmes's Avatar
IACV only works at idle (hence the name). Does the idle "surge"? Surging can be a vacuum leak. If you had the TB/IACV off to clean, check the gaskets. Check for other vacuum leaks (hoses, etc...)
Dave
Old Sep 6, 2003 | 10:27 PM
onegoode's Avatar
Dave
Were you using premium fuel?
Old Sep 6, 2003 | 11:45 PM
Beldin's Avatar
Fat Kid
This would deffinitelly do it. A friend of mine put regular gas in my car without telling me they were going too. My car ran like crap for that whole tank.
Old Sep 7, 2003 | 01:44 AM
I heard though that the IACV will function upto about 4k rpms... i think i read that here somewhere... That's why i fugred in 5th, running at around 3.5k the trottle is open, but theres also air coming in through the IACV. dunno... :-/
oh, and i checked the resistenc of 2 coil packs today... each had different resistence :-/ that can't be good
Old Sep 7, 2003 | 04:46 AM
You could check your ECU for codes.
The resistance on the coil packs may not match up perfectly, but they should all be very close to each other. If I remember right, they should be 32 kohms (maybe a different scale, but 32 something). But this is only if I'm remembering right.
Does your car idle rough? That would be a good sign of a vacuum leak.
On my '97, the IACV ticks at idle. This ticking goes away as soon as you rev it a little.
I would definitely check the ECU for codes, and go from there.
Dave
Old Sep 7, 2003 | 07:10 AM
njmaxseltd's Avatar
Change your fuel filter and run a bottle of Techron through your next tank of gas. See what happens after that.
Unclejunebug
Apr 2, 2016 05:42 AM
05RLS2
Sep 27, 2015 09:24 PM
foodmanry
Sep 24, 2015 12:02 PM
lrb6805
Sep 17, 2015 04:49 PM
