Anyone give me a real clear runthrough on tightening throttle cable?
Old Sep 6, 2003 | 06:13 PM
zemp68's Avatar
Not sure what to tighten. Thanks!
Old Sep 6, 2003 | 06:44 PM
njmaxseltd's Avatar
There are two cables attached to your throttle body. One is from the cruise control and the other is from your gas pedal. Just take the excessive slack out of both of them. Don't go tight or you may experiance a high idle speed.
Old Sep 6, 2003 | 06:46 PM
zemp68's Avatar
Yes, I know all of that, but how to I take the slack out????
Old Sep 6, 2003 | 10:42 PM
Torgus's Avatar
uhhh..... rtfm
Old Sep 6, 2003 | 11:34 PM
Beldin's Avatar
Fat Kid
If you don't already own a Haynes/Chilton/whoever else makes books for cars, you need to go buy one and read it. If you already own one open it up and read it.
It is worth the money.
Old Sep 7, 2003 | 07:26 AM
njmaxseltd's Avatar
Loosen the lock nuts on bracket and adjust it, pretty straight forward. Pulling the cable back makes it tighter. You'll see.....
Old Sep 7, 2003 | 07:39 AM
zemp68's Avatar
ok, thanks.
Old Sep 7, 2003 | 03:15 PM
ZeRo MaX's Avatar
kool... i'm gonna need help on this too
Old Sep 7, 2003 | 03:22 PM
zemp68's Avatar
Ok, I just did it...I wasn't sure which NUTS people were talking about, but I figured it out. The nuts in question are the two that are on top of the unit, on either side of a bracket, that the wires are threaded through...loosen them both up and you can move and adjust the tension that way, and you don't have to touch the cables...which I thought you did...works great, start your car, to make sure you didn't tighten them too tight and voila!!!
Old Sep 7, 2003 | 03:24 PM
zemp68's Avatar
Much more response now...mine cable had like a quarter inch play in it!
Mar 12, 2020 12:06 AM
bryants95max
Oct 2, 2015 12:52 PM
thenewguyy
Sep 12, 2015 11:12 AM
pktaske
Sep 4, 2015 08:40 AM
