Ground Control COILOVER USERS: Q about lowest setting, please READ...
OK - they are on the lowest setting, and there is still about 1.5"(2finger) wheel gap. Shouldn't the car sit lower? BTW this is with 18" rims and 225 tires. Maybe the 245's are what i need to further reduce the gap...
Now a thought - installation wise - did you keep the spring caps as a part of the front assembly or leave them out - without them it would result in a 1" lower stance.
As for the rears, the spring caps are the actual strut mount, so leaving them out is not an option. How to get the rear lower?
The strut bearings go directly on the silver spring cap - but do you also need to keep a set in the factory location, on top of the spring cap and under the mount.....
Any help or insight from your install experience is appreciated.
The only way to make them lower is to buy shorter springs from ground control. The springs you have won't go any lower, you need the shorter springs or the same size springs with less spring weight, but I would jsut get smaller springs with the same weight.
Welcome to crappy coilovers, get you some JICs, you'll be as happy as I am, I promise.
Thanks - is there a reason for you going with the JICs rather than the Cattmans. I would have thought for sure those chrome cattmans were right up your alley, how are the JICs finished?
And yes I get happy just looking at your drop.
![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
And yes I get happy just looking at your drop.![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
And as far as adjustability, the cattmans are lowered by the spring purch as opposed to the JICs lowering the entire unit into the lower brackets and keeping all spring travel. I am riding one finger gap in the front and tucking tire in the rear and I have the same spring/strut travel as a I would with 2 finger gap all around or higher.
They are a gold color, not sure what the finish, possibly nickel.
