E-Brake
Old Sep 14, 2003 | 03:13 PM
apeg's Avatar
E-Brake
I posted this a couple weeks ago and was referd to a web site but i lost the URL and the search seems to be down?
my E-brake is having some problems. it is very lose. i proped the car up pulled the e-brake and the back right wheel could still spin. the left was solid.
anyway the URL was explaining how lifts crunch the brake cable and mess it up, and how i should bend the braket so that it wont crunch, i get how this will prevent future problems but will this slove my problem as well? or do i have to get the brake wire replaced?
Thanx for the help guys
-Ohhh and VERY VERY off topic just wondering if anyone has attempted to "RED" out Altezza lights? pics? maybe?
Old Sep 15, 2003 | 05:40 AM
StygianMax's Avatar
I'm guessing it's this one http://www.motorvate.ca/mvp.php/303
Old Sep 15, 2003 | 07:14 AM
apeg's Avatar
Perfect thats the site... but like the guy from the site mine is cut.. is it a big job replacing the cable? should i let the shop take care of this one?
Old Sep 15, 2003 | 08:33 AM
StygianMax's Avatar
I had to replace my driver side e-brake cable & I decided to let the dealer do that. The Haynes manual doesn't provide enough details for me to chance it. FYI - there is a e-brake cable for each side. They both connect to a "balancer" which is then connected to the hand brake. (sorry, it probably doesn't make much sense without having a picture in front of you!).
I'm in Toronto and the cable cost about C$100 and it took about 1hr of labor to get it installed. Ouch! btw, I busted my cable boot right by the rotor when I was trying to wrestle my rear caliper off the very first time I changed my own pads.
Old Sep 15, 2003 | 10:57 AM
apeg's Avatar
thanx for the info StygianMax i probably will just take it to the shop..
BTW did you get you "under hood" painted @ a body shop? or did youdo it your self?
Old Sep 15, 2003 | 11:59 AM
StygianMax's Avatar
I painted the hoodliner myself. After I painted my sprakplug cover with high temp enamel paint, I still had 80% of the spray can full. So I decided to go at the hoodliner. In hindsight, that was a good and bad idea. The painting turn out nicely with the color. Though because I used enamel paint, it's got no flex agent in it. As a result, the paint has got a brittle finish. To do it properly, you should really try to find a paint that's both got high temp characteristics AND not got enamel content which becomes brittle once dry.
It took me about 5-7 light coats of paint to get a finish that even in color depth. As with any good painting practice, more light coats is better that fewer thick coats.
Old Sep 15, 2003 | 12:34 PM
apeg's Avatar
thanx for the info
Lowered_a33
Aug 24, 2015 04:35 AM
Adambrown_2001
Feb 27, 2002 01:41 PM
buckwilly4
Sep 20, 2001 02:37 PM
Max2000
Nov 24, 2000 05:56 AM
PiotrC70
Nov 17, 2000 08:06 PM
