I'm Going Crazy!!
High Pitched Squaking Noise
I'm going absolutely mad with this high pitched squeak coming from the wheels/axel or something like that. I've had the break pads checked and it's not them. I DON"T KNOW WHAT THE HELL. And I don't want to take it to the dealership so they can give me some BS. It's mainly at slower speeds but I can still hear it almost up to 50 mph. It sucks! Any clues??
Originally Posted by PoePoe2797
Did you ever try the rotor dust shields? They tend to rub the rotor making a squeal or maybe grind... I had it on mine and it was VERY annoying. just bend them back a little and see if it works, cant hurt to try
I'll give that a try, thanks. Could you direct me to them a little more specifically?
You literally cant miss it.....look at your rotor, and take a look behind it, its about the same exact size as the rotor, it just covers the back side. It should just be a flimsy metal surrounding directly behind the rotor...you dont even need to take off your wheel, just shove a screwdriver through your wheel and push the shield back away from your rotor
Thanks a bunch man. If this solves it, I'll be forevor indebted to you
ivorton23
Sep 28, 2015 09:08 PM
ColdCananda
Sep 20, 2015 10:45 PM
Maxima30
Sep 7, 2015 06:13 PM
