Clear Corner Rewire Without Mutilating My Bulbs?
Old Sep 18, 2003 | 04:55 PM
MaximaEvolution's Avatar
Does anyone know how to re-wire the cornering lights, so that it will be bright, without destroying my bulbs? I looked in VQ and thats the "mutilation" procedure. Please help.
Old Sep 18, 2003 | 05:01 PM
mzmtg's Avatar
Minister of Silly Walks
It's easier to chop the nubs off the bulbs than to rewire it the "other" way.
Plus, bulbs are only like $1 each.
Old Sep 18, 2003 | 05:16 PM
LastBoyScout's Avatar
could someone post the correct way to do it other than the bulb mutalation way?????
I prefer not having my bulbs go out all the time like they did on my sentra using that trick.
Old Sep 18, 2003 | 05:32 PM
ivelweyz
My bulbs have yet to go out in about a year. As long as you use electrical tape nothing will go wrong...
Old Sep 18, 2003 | 06:21 PM
mzmtg's Avatar
I've had mine cut for 2 years.
No problem.
Old Sep 18, 2003 | 06:32 PM
RA030726's Avatar
I'm nutty for Nissans
Reverse the two postive wires, ill go check the colors for you in a few.
Old Sep 18, 2003 | 07:36 PM
polarg bulbs are not $1, plus its more profesional to just rewire it properly
Old Sep 18, 2003 | 08:07 PM
gtr_rider's Avatar
192.168.1.1
Welcome to the org
Old Sep 18, 2003 | 08:24 PM
Gen8888's Avatar
(atleast 10 char long)
Old Sep 18, 2003 | 10:21 PM
MaximaZX's Avatar
i agree that it is kinda strange to cut up the bulb, but it is SO easy to go back to stock if needed (if you mod the bulb, not the wiring). plus, i dont like messing with the electrical system too much (i have seen too many cars catch fire due to incorrect wiring,) unless you plan to rewire it correctly (solder the wires together, not just twist and tape) just mess with the bulbs
Old Sep 19, 2003 | 07:48 AM
That's just it, I dont plan on going back to stock, that crappy dull light stinks. It looks 100 times better when its fully lit.And of course I plan on doin it the right way, I could never hurt my baby. Anyone know how to wire it the right way?
Old Sep 19, 2003 | 08:30 AM
Unibomber's Avatar
filing off one of the nubs is easier than rewiring a whole corner light
heh...why would you need polar G bulbs when you can get a 1 dollar bulb from wal mart that is brighter than a polar g bulb
Old Sep 19, 2003 | 08:37 AM
ivelweyz
Some people just think they know better, then they mess up trying to rewire their bulbs, their car catches fire, and we laugh at them. Maybe next time they'll listen...
Old Sep 19, 2003 | 11:22 AM
Unibomber's Avatar
see
worst that can happen with cuttin a nub off is the bulb burns out faster
id rather have a bulb burn out then replace a 45 buck wire harness
Old Sep 19, 2003 | 02:54 PM
RA030726's Avatar
http://www.geocities.com/bracecraig/...e.html#cornerb
There is a diagram with directions for rewiring the lights. I'd check the wires i swapped, but its raining buckets right now. You have nothing to worry about doing this mod, you'll blow fuses b4 burning up wires.
Old Sep 19, 2003 | 03:21 PM
ptatohed's Avatar
Licensed to Spell
:o)
Everybody always thinks there are one of two ways: Perform 'surgery' on the bulb or perform 'surgery' on the car's wiring system. I didn't want to do either! All I did was 'force' my bulb in without shaving the nub. It is not that difficult. It's a little tight but certainly do-able. Just take your bulb out, insert it back in so the lower nub goes in the upper hole. The upper nub will just be tight up against the wall making no electrical contact. Good luck.
- Josh
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
