WRITEUP: How to change the clutch slave cylinder hose (/W PICS)
Old Sep 18, 2003 | 05:22 PM
bignick's Avatar
What is up,
If any of you with a manual tranny notice you have to fill up the clutch reservoir every few days, its probably because your slave cylinder hose has a slow sweat (common problem it seems). I changed it today in about an hour and a half (this writeup should get that down to half an hour). The hose itself costs around $40. I picked mine up at *** Nissan (Bronx, NY), as they were one of the few who had it in stock. Here goes:
Tools needed - 10mm and 12mm wrench, 12mm socket. 1 - 2 bottles of DOT 3 or 4 brake fluid.
DISCONNECT THE + and - TERMINALS OF THE BATTERY
You'll be working right over the battery, the last thing you want is to graze the terminals (goodbye armhair). Also, you're gonna want the car to be cooled down for this, there's coolant hose etc right there. Wait at least 4 - 5 hours after a drive to tackle this...
Step 1: Remove banjo connector coming from master cylinder
This was pretty simple. There is a 12mm bolt on top of the 'box' side of the slave cylinder hose. Remove this with a socket wrench and an extension (you don't need the extension, but getting leverage down there is hard as ****). Clean it up, and then put the bolt aside. Get into the car and press down on the clutch 5 or 6 times to empty out the reservoir (might as well start off with clean brake fluid). The clutch will fall to the floor, so you'll have to pull it up with your hand. Seperate the banjo connecter from the box. Notice the brass washer that comes off with it; clean that up and set it aside.
'Box' end of clutch hose:
Brass washer:
Step 2: Removing slave hose from motormount
The 'box' end of the hose is attached to the motormount by 2 screws, 10mm in size. Either a socket or wrench will work. You have to unclip the massive wire connecting the battery to the starter from the clip. Just look at the thing and you'll get the jist of how it works. For the unimaginative - stick something flat under the tab and lift, the wire will unclip. Leave the wire attached, just push the wire over a little with the wrench while your removing any bolts. The whole clip assembly will then come off with the whole box end of the hose.
Step 3: Removing hose from slave cylinder
Pain in the *** right here. This thing is on TIGHT so find the longest 12mm wrench you own and go at it. Just follow the other side of the hose up under the engine (you can see it if you get the angle just right from the intake side of the engine). I had a 5" long wrench so doing this by hand was/is impossible. To solve this, I just went caveman style - get the wrench to hang on the bolt, then grab a hammer... Cracked it loose in 2 tries. Unscrew the rest by hand. There are 2 washers on that bolt - one above the banjo connector and one below. Now that you know, you won't be dropping them somewhere inside your engine bay, right?
Step 4: Installing new hose
New hose (upside down):
Follow the steps you just took, backwards. Put the banjo connector on the slave cylinder side first (make sure you have one of those brass washers on each side of the connector). Screw that in tight. Do the same to the 'box' end with the hose attaching from the master cylinder. Attach the 'box' end of the slave hose + the cable holder piece (for the starter power cable) to the motormount.
Step 5: Bleeding the clutch
Once everything is nice and secure, you have to get all the air out of your hoses and replace it with brake fluid.
http://www.motorvate.ca/mvp.php/803
That's an excellent writeup (and site) on how to bleed your clutch lines.
There you go; no more worrying about getting stuck in traffic with no fluid! Total cost should be around $50, hose + fluid (+ bandaids for burnt knuckles).
Nick
Old Sep 18, 2003 | 05:23 PM
bignick's Avatar
more pictures
Some more pics:
Reasons to put down some newspaper in your driveway:
Old Sep 18, 2003 | 05:24 PM
bignick's Avatar
final round of pics
'Box' end with banjo connector + washer still attached (bolt removed already):
Brake fluid that leaked onto the clutch boot from the old hose:
Step I had to take to prevent the fluid from totally leaking out everyday (this slowed down the leak to a once a week topoff of fluid). Also, notice the blood on the left connector :
Old Sep 18, 2003 | 05:57 PM
gtr_rider's Avatar
192.168.1.1
luke@vqpower.com care to share?
Old Sep 18, 2003 | 06:24 PM
bignick's Avatar
If you mean put it up on your site, then yea, go for it (credit would be nice too )
Old Sep 18, 2003 | 06:50 PM
gtr_rider's Avatar
192.168.1.1
http://www.vqpower.com/v2/modules.ph...howpage&pid=67
Old Sep 19, 2003 | 09:05 PM
ThurzNite's Avatar
daaaaang. I wish I saw this earlier. I paid $60 + $40 labor for my mechanic to do it.
Jae
Old Sep 29, 2003 | 09:24 AM
BobK's Avatar
Thanks for creating this write-up your effort is appreciated. This will come in very handy when I change mine this week.
Old Sep 29, 2003 | 11:41 AM
bignick's Avatar
No problem. It only took me slightly longer to do the repair while taking pictures, and I know how much it helps to have a step by step (thanks motorvate.ca, vqpower.com etc) so why not. Now if everytime someone did an undocumented mod/repair, they did a writeup.
edit -
btw, my cardomain links don't seem to be working, but if you goto the site here - http://www.cardomain.com/id/ragingroin - you can see all the pics.
Old Sep 23, 2009 | 04:41 PM
AJSpades21's Avatar
sorry for the bump but it wont let me make a new thread and this was the closest i could find to the topic. ive been reading all over the forums and still cant find an answer. i removed my slave cylinder, still working on the master, im replacing both. i was wondering if its possible to just do away with all the extra lines and just run a rubber hose from the master to the slave. my lines are leaking anyway and all the connectors are corroded to s%1t. i wanna just rip out all those extra lines, i could care less about the upper bleeder valve.
Old Sep 23, 2009 | 07:54 PM
pmohr's Avatar
No more Maximas...
Yes. Well I wouldn't just use any old 'rubber hose', personally. Get the full SS line from the GD section, ~$40 and a much simpler system.
Old Sep 24, 2009 | 12:29 AM
ThurzNite's Avatar
Make sure it's the full line, not just the 6" one from the junction to the slave.
Or get some metal brake lines, and bend it appropriately connecting the 2.
I think the extra lines in the stock system is to absorb shock of the clutch engaging.
Dr J
Old Sep 24, 2009 | 02:48 AM
KASRA's Avatar
This is very easy process:
1) Take out the battery and all the air system( filter, air mass flow,...)
2) now you can see the trnsmission, on tupper side of the transmission on your right you can see the starter and beside it the slave cylinder.
3) puta pan under the transmision so the fluid won't spill on the floor.
4) unscrew the bolts and take it out.
5) onc you'v replaced it, make sue that you adjust the clutch, to do so you need to use the break fluid and put itt in the master sylinder and open the small silver thing on the slave cylinder and pomp the clutch till the fluid comes out ofthe whole and hold the clutch till someone tighten that thing...I jsut don't know the name... when you feel comfortable with the clutch, it's tim to out everything back.
Old Sep 24, 2009 | 06:18 AM
TMAXDOUT's Avatar
the pics arent working for me.
Old Sep 24, 2009 | 07:03 AM
pmohr's Avatar
No more Maximas...
Check out the date on the first post.
vingodine
45
May 21, 2016 12:46 PM
vanebecker
Aug 17, 2015 08:24 PM
acw
Aug 7, 2015 04:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
