Ok, my clutch squeals when I press and depress the pedal. I know it's a combination of pedal squeal and something near the slave cylinder. Heres the info I need from you guys. I plan on pulling the rubber boots off the slave cylinder and clutch fork and lubricating them. The only problem is, what exactly do I lubricate and with what? Once I take the rubber boots off, do I get some silicone grease and rub it around? Please be specific with this.
I heard greasing the joint where the fork attaches to the T/O bearing is recommended to be greased but can I access it from the top of the tranny where the boot pulls off? And what lubrication should I use, WD40 or some kind of silicone lube (i have siliglyde from napa) ?
