motor mounts of the 3.5 vs the 3.0
Old Sep 22, 2003 | 09:56 AM
waveridr85's Avatar
yes a project may be coming soon, i need to know how the mounts on the 3.5 l engine from the 2k2+ max's are comparred to ours? do they line up? also how about the tranny and axles? how will they work. basically im looking to swap a 3.5 enigne w/ the 6 spd tranny in the next 4 months. thanks for the help
Old Sep 22, 2003 | 11:00 AM
bignick's Avatar
I don't think its possible to drop in a 3.5 into our engine bay.
Old Sep 22, 2003 | 12:23 PM
maxS
it is possible... everything in life is possible.
but i would not recommend you do that at all.
do not even think of it.
unless you are looking for fun and lots of trouble
Old Sep 22, 2003 | 02:00 PM
JDM4LIFE's Avatar
i don't think anybody knows the answer to that question on here. however, i'm sure that you could get custom mounts made, if anything. 90% of the time with import swaps i've encountered, you have to go that route anyways. due to the space limitations on the 4th gen, i'm sure you'll need them anyways...
Old Sep 22, 2003 | 04:15 PM
waveridr85's Avatar
what do you all think the estimated cost of this would be?
Old Sep 22, 2003 | 04:52 PM
Anachronism's Avatar
The general consensus is it would be much more cost effective to do a turbo or supercharger. Check here and here for more information.
Old Sep 22, 2003 | 10:07 PM
mforrest100's Avatar
Jeff from Max Tuning dropped the 6 speed tranny in with a 3.0.
Old Sep 23, 2003 | 09:31 AM
waveridr85's Avatar
thats actually who i would ask to do this install haha, the reason i am looking also to do the whole swap is not just the power put the long range possibilites with the engine. it would have a lot less miles on it and then i could supercharge a 3.5 instead of a 3.0, the potential is just greater with taht motor. i am guessing around 5k for parts and labor?
Old Sep 23, 2003 | 09:36 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
6spd will work I should have mine done this weekend just need to install driveshafts and pedal. the down falls are removing stock 4th gen mount and you need to have the engine out to make it easier. 3.5 bottomend bolts in to stock mounts.
Old Sep 23, 2003 | 09:37 AM
MaxSpeedSE's Avatar
All depends on what parts u use....keep the 5 speed tranny , and u save your self a part right there.... ?
Old Sep 23, 2003 | 10:50 AM
maxS
here is what i used:
http://images.cardomain.com/member_i...111_4_full.jpg
Old Sep 23, 2003 | 10:59 AM
MAXimumHP's Avatar
There really should be a FAQ on what parts are interchangeable between the 3.0 and 3.5 and what will mount to what. There always seems to be a lot of questions on this subject.
Old Sep 23, 2003 | 12:17 PM
silver99
IF YOU CAN FIT A V8 INA VEGA AND PINTO YOU CAN FIT A 3.5 INTO A 3.0 ENGINE BAY
LOL sorry for the caps it was supposed to be sorta funny.
i think its very possible, my interest however is putting the V8 VQ into my older 90 maxima. Now that would be some serious shht. As far as engibe mounts go what u would need is to take the 3.5 engine mounts and mount them in place of the 3.0 mounts. Of course i make it sound easy but anyone looking to do this sort of thing isnt looking for an easy job.
Old Sep 23, 2003 | 12:32 PM
MaxSpeedSE's Avatar
Would the 3.5 work with the 4th gens Ecu and wiring, or would all that have to be pulled and changed out too?
Old Sep 23, 2003 | 12:44 PM
MAXimumHP's Avatar
A lot of the sensors are different, not to mention the variable intake and valve timing programs. You would have to swap harnesses and ECU's
Old Sep 23, 2003 | 02:43 PM
skeelo34's Avatar
Does anyone know if the 3.5 would mount the same as the 3.0? I mean, would the mounts line up the same way? I'm assuming everyone thinks it cant. If it could, what would be so difficult about this swap?
Old Sep 23, 2003 | 03:10 PM
TILLEYS99's Avatar
mounts are the same for the motor I know I have one sitting here already fit up and waiting for install but the 6spd needs the mount welded in and stock mount removed.
ardika's Avatar
6 spd 3.5 to 4th gen???
Hmm.....
Old Sep 24, 2003 | 09:10 AM
maxS
it does not make any sense... really.
i've done a few swapps on 96 and 2000 and i can say it again:
Old Sep 24, 2003 | 09:15 AM
2naboy's Avatar
I had conteplated doing this before but it seems like it will be too much of a hassle seeing that after you do the swap you will probably put a turbo or SC in it. Why not just use the time and money involved and get a and turn the boost up.
Old Sep 24, 2003 | 02:03 PM
maxS
Exactly.
Or just get a better car - say 5th gen max or somthing else
Old Sep 24, 2003 | 02:33 PM
MaxSpeedSE's Avatar
Originally Posted by maxS
Exactly.
Probably due to the fact that this motor in a 4th Gen., witch is like 600 pounds lighter then a 5th gen would kill a 5th gen.
Old Sep 24, 2003 | 03:02 PM
d_warner's Avatar
Old Timer
From what I've read and heard, use the block mount from a 4th gen and mount it to the 3.5
Old Sep 24, 2003 | 03:43 PM
2naboy's Avatar
What I have always wondered is whether the heads on the 3.5 will fit on that of the 3.0 or the other way aroung. At least this might reduce the hassle.
Old Sep 24, 2003 | 04:48 PM
ardika's Avatar
You guys are probably right
You know, sometimes you come into that thin red line between hobby and economic feasibility. I really wish that my 4th gen comes with 6 spd, or 5 spd...but what I have is an auto.
For me, after thinking it over and over again, putting body kits and Cefiro lamps are cool....but the $$$ outweigh the benefits of doing such mods. The same thing apply to 4th gen with 6 spd tranny. It will cost a lot of $$$ (4 grand all said and done, perhaps?) but then again, you could save up your money, wait for 3-4 years and get a nice used G35 Coupe (well, they cost more, but hopefully you get the idea).
I would really like to have 6 spd in my 4th gen....hell, even the 3.5 with 6 spd into 4th gen for that matter, but then I probably have to apply for special insurance to cover my invested $$$ if something happens to my car.
Old Sep 24, 2003 | 05:36 PM
MaxSpeedSE's Avatar
Ardika,
Things are always expensive when there first new....look at the 5 speed conversion when that was new to the org...a year or so later i was able to get my hands on all the parts for 1000 dollars, and sell my auto for 400 so i basicly payed only 600 bucks...and what its given me, its well worth that and more... so like i was saying, after time pass's things become from more realistic.
Oh yeah one more question...putting a 6 speed tranny on the 3.0 motor, what would be the advantage of this?
Old Sep 24, 2003 | 06:06 PM
ardika's Avatar
You are correct
Ardika,
True, but I am having a hard time to convince myself that Stillen body kit, which in my opinion is the best kit out there (subtle), is worth the price since you will have to drive to be more careful (lower ground clearance, paint matching, etc.). Again, this is just my opinion, though. I love seeing a well done body kits on any car.
I would think that the advantage is presumably better design (compared to 5-spd tranny), based on the "newer" design of the 6 spd (reliability) and better gear ratio on NA cars. If you are supercharged/turbo, perhaps high gearing is fine, but NA cars....sometimes we need that "extra" gear.
Old Sep 25, 2003 | 07:10 AM
waveridr85's Avatar
ok, people say just crank up the boost a lil, now imagine that i do this swap and install a s/c or turbo later, then crank up the boost a little bit. the in the long run, the 3.5 swap will yeild greater power and greater modding ability.
ahh yes, someone stated that they were a 3.0 auto, i know the feeling iam one as well.
alos a key thing to remember is that i will be putting in a new engine and tranny, this swap will make my car last another 7yrs longer too, s/c the car and you still got the same wear that was on the engine
Old Sep 25, 2003 | 07:11 AM
waveridr85's Avatar
and remember, alot of these engines will be showing up, since they can also be found in the alt's too
Old Sep 25, 2003 | 10:16 AM
MaxSpeedSE's Avatar
U have to understand that the 3.5 motor does have an advantage over the 3.0 in an all motor setting... but in the long run with the boost....its pointless cuz the motors share the same block. And I believe if I remember right the stock blocks can handle like 450 HP. So just because u have the more aggressive motor in there doesn't mean it will out perform the 3.0 with boost...just means u will have to boost less to get the same power out puts the 3.0 gives...
Old Sep 25, 2003 | 11:04 AM
Ninos_Maxima's Avatar
be the change u want2C
Dont let these people put you down, If you do it, you will be Maxima King!!! If you try but dont succeed you will still be on of us, Cant assure you on the flaming though
Old Sep 25, 2003 | 01:18 PM
waveridr85's Avatar
haha, im really looking into to it
Old Aug 8, 2012 | 03:02 AM
01se5spd's Avatar
did this swap go with ease? if not what out of the 3.5 would i need to complete this swap?
Old Aug 8, 2012 | 05:35 AM
max1008's Avatar
Noob - This post is almost 10 years old! There are how to on doing this....
Old Aug 9, 2012 | 02:42 AM
01se5spd's Avatar
i know but this was the only thread mentioning the 3.0 with the 6 spd trannyi saw
Maximan190
Dec 16, 2015 06:01 AM
AaronL
Sep 23, 2015 03:34 PM
vball_max
Sep 17, 2015 10:01 AM
QueensMAX
Sep 15, 2015 04:14 AM
MaxRPM6
Sep 11, 2015 06:56 PM
