Burned smell when accelerating hard
Old Sep 23, 2003 | 05:08 PM
MaxaholicNY's Avatar
Hey guys. Im not sure what the problem is but whenever I accelerate moderately hard, I get a burning smell coming from my car. Im pretty sure its not my cat cause it does not smell like rotten eggs. Any help would be greatly appreciated. Thanks guys.
Old Sep 23, 2003 | 05:20 PM
njmaxseltd's Avatar
Belts slipping?
Old Sep 23, 2003 | 11:04 PM
DoGGy
its the smell of the accord u just smoked. im sure his a$$ is on fire after u pushed ur max hard and owned his VTEC
Old Sep 24, 2003 | 02:32 AM
SEDaveMax's Avatar
My guess would be that you probably have oil leaking somewhere on your exhaust system and when you start to accelerate or put the car under a load your exhaust gas temp raises thus giving you this burnt oil smell. Just my guess. Have you try to look in the mirror or have a friend follow you while you jump on it to see if you can see any smoke? I hope this helps you. You may want to start by checking your valve cover gaskets for any leaks.
Dave
Maxima SE
Old Sep 24, 2003 | 09:34 AM
Thanks Dave. I will check up on that.
Doggy - That actually happened 3 weeks a go. I smoked my friends Accord Vtec and my other friend's riced out civic at the same time!!! It cant get better than that.
Old Sep 24, 2003 | 09:43 AM
DoGGy
i just knew it
Old Sep 24, 2003 | 12:26 PM
TAPOUT's Avatar
You will lose
Burnt Rice???????
Old Sep 24, 2003 | 07:39 PM
infinitiman96's Avatar
my guess is that your smelling sulfur from the gas you are using, use a different brand of gas and see if it goes away. I work for a lexus dealership and lexus's smeel the same way when they run some exxon fuels, goes away when using a different brand
Old Sep 24, 2003 | 08:16 PM
SXN's Avatar
SXN
if it doesnt smell like rotten eggs, its not the cat, if it doesnt smell rich its not a gas leak. do you know how coolant smells, weird kinda sweet smell, but its still burning and toxic, so hard to describe. could be an oil leak, small drops burning off...only leaks when high engine pressure/rpm, leaking gasket or something
Old Sep 25, 2003 | 12:23 PM
LastBoyScout's Avatar
smells like burning copper right?? I know that my car made that same smell the first time i gave the Transmission a good work out. Now it doesnt make that smell anymore. My tires still smell like crap after i do burnouts tho....anyone have a way to make that smell better?? LOL
Old Sep 25, 2003 | 04:42 PM
SXN's Avatar
SXN
actually...yes. a lot of times (when we do huuuge burn outs) me and my buddies use different stuff to make it slip easier. tire shine stuff makes it slip more and smell less, and RC car tire traction compound (comes in different scents) or marvel mystery oil (smells like pepperment) makes slipping easier...but at the same time makes it smell a loooot less. but whats wrong with burning rubber smell?
D Mason
Jun 21, 2016 04:43 AM
hayne
Oct 5, 2015 11:53 AM
Need help
23
Oct 2, 2015 08:56 AM
fx4five
Oct 1, 2015 04:58 AM
