1997 Maxima Exhaust Y-Pipe Removal
Old Sep 25, 2003 | 03:04 AM
rocketman's Avatar
Wonding if anyone has removed the stock Y-Pipe. It took me hours to get the nuts off that attach the Y-Pipe to the front and rear exhaust. The problem is the Y-Pipe still won't come off. I tried to chisel the pipe flange from the front exhaust manifold. It did budge a little, but just a little. Don't know how to even attempt the rear, with the limit space. Is there anything else holding it in?
Also, I read that the wires to the oxygen sensors can not be removed. Does that mean you have to remove the wires on the engine side and let them hang down?
Any ideas, thanks.
Old Sep 25, 2003 | 04:04 AM
maxNYC's Avatar
might have to use a torch to heat up the area. Its sounding like its seized.
Old Sep 25, 2003 | 05:30 AM
rocketman's Avatar
Answer
I guess I answered my own question about the y-pipe. In addition to the nuts that hold the ypipe to the front and back manifolds, there is a tab with two bolts that hold the ypipe to the underside of the car. Once I removed those two bolts it came right out.
Old Sep 25, 2003 | 10:57 PM
PedalKick's Avatar
Ha Ha, same happened to me!. There I am, tapping on the y-pipe flange
and I finally see that it's moving, then discover the two bolts.
Old Sep 25, 2003 | 11:39 PM
BadKarma99-4spd's Avatar
in the future try using the liquid wrench or a similar product, i let it sit for about 5min and then my bolts came off like they were jello. of course mine is a 99 so they had only been on for like 4yrs.
Greenmaxspeed
Aug 31, 2015 09:06 PM
wyobbagy
Aug 15, 2015 02:28 PM
09maxshawn11
Aug 14, 2015 10:07 PM
Samedi
Aug 13, 2015 04:05 PM
jchronis2552
Aug 13, 2015 07:48 AM
