How much should I pay for a Tune-up?
Old Sep 25, 2003 | 12:56 PM
myke321's Avatar
Hey, just wondering what a tune up might cost, the Nissan dealer wants $229, that sound like a lot. Can some one tell me what the going rate should be. I'm in California if it helps. Thanks.
96 SE
Old Sep 25, 2003 | 01:03 PM
The Gange's Avatar
Depends on what they plan on doing in the tuneup. 229 doesnt sound that bad to me.
Old Sep 25, 2003 | 01:47 PM
mzmtg's Avatar
Minister of Silly Walks
None. DIY.
Old Sep 25, 2003 | 01:50 PM
maxNYC's Avatar
$229 sounds cheap if it includes brake pads.
Old Sep 25, 2003 | 02:07 PM
slavik'sMAX's Avatar
i also k its not bad, since dealers charge about 75 bucks/hour for labor............so if you don't want to do it yourself, you'll never get too much below 200
But what does dealer mean by tune up? spark plugs and "check everything"........if thats the case definately DIY
Old Sep 25, 2003 | 02:54 PM
The Gange's Avatar
Agreed. Doesn't sound like they are going to do much in terms of tuning up. You're best be is to get the parts and do it yourself.
Old Sep 25, 2003 | 03:14 PM
myke321's Avatar
Thanks for everyones reply.
Old Sep 25, 2003 | 04:40 PM
davey6693's Avatar
Pay as much as it takes to buy the parts. A 60k can easily be done yourself.
Old Sep 25, 2003 | 07:05 PM
Jatan's Avatar
My mechanic charges about $150 for a full tuneup. I did mine myself It was easy
Old Sep 25, 2003 | 07:26 PM
Maciek's Avatar
What all do you do in a tuneup? Mine is approaching 130K and I only had it for 3 months (12K miles), so I don't know what has and hasn't been done to it.
Thanks for all your input
Old Sep 25, 2003 | 07:39 PM
Jatan's Avatar
New plugs, air filter, fuel filter, PCV valve, clean TB, clean IACV, and oil change. You can do a coolant flush and change the tranny fluid if you want. http://www.motorvate.ca has some useful info.
Change the knock sensor if you have the ghost code. If you have the money, change the O2 sensors. Check your tire pressures
Old Sep 25, 2003 | 10:31 PM
SlowJoeMax's Avatar
ghost code??
Old Sep 26, 2003 | 01:40 PM
Jatan's Avatar
Ghost code is a code that doesn't turn on the CEL (Check Engine Light). If a knock sensor goes bad, it won't turn on the CEL and tell you (other things will). You have to check the car for codes and if it shows 0505 then everything is working fine.
Old Sep 29, 2003 | 08:15 AM
Maciek's Avatar
Guys, please excuse my ignorance and enlighten me how do you get those codes you are talking about? Do you have to plug a lap top to the ECU or what? I want to find out if my KS is bad.
Old Sep 29, 2003 | 08:20 AM
ivelweyz
maciek read the stickies at the top of the 4th gen board. I'd explain but it's easier if you just check'em out yourself...
Old Sep 29, 2003 | 05:22 PM
Phatmax98's Avatar
good price? well all depends on what you want done. I had my mechanic do everything in the Haynes manual at 63,000 miles, new front brake pads and rotated rotors all for about $239. That also included every filter, spark plugs, coolant flush, tranny fluid, clutch fluid..mmm I think that's it..I'd have to look in the book for a full list. Good luck!
Old Sep 29, 2003 | 05:23 PM
Kevlo911's Avatar
Kevlo for President
http://web.archive.org/web/200111091...k_service.html
plus some of hte things on motorvate's site
Old Sep 29, 2003 | 05:28 PM
hoodedmunkee's Avatar
that price isnt bad at all.i was qouted $475 for a 90k service but if i wanted my plugs replaced its $555.
Old Sep 29, 2003 | 05:51 PM
Kevlo911's Avatar
Kevlo for President
wow thas a crzy price, i would not pay more hten 250
Old Sep 29, 2003 | 05:58 PM
Sprint's Avatar
$0.0000000
Old Sep 29, 2003 | 06:00 PM
Kevlo911's Avatar
Kevlo for President
u can use sprintmax's write up to change spark plugs. it can be found at www.sprintmax.com
Old Sep 29, 2003 | 09:21 PM
well..i didnt go for the offer anyway.what i did was i asked them for a list of the things that theyre gonna do and ill do what i can and check it out like a mini checklist.whatever i cant do,ill let them do it.i still have the right mind to not pay for that ridiculous amount.
RealityCheck
Oct 2, 2015 06:34 PM
Socalstillen
Sep 26, 2015 12:01 PM
Cotozic
Sep 23, 2015 11:55 PM
ef9
Sep 10, 2015 10:35 PM
