I need a B.J.
I need a B.J.
How extensive is it, as a DIY project to put new brake rotors and calipers on? I have no experience and am curious if it can be done within a weekend. Any advice would be helpful.
-King Ryan-
-King Ryan-
Man its sooo easy. Unless you are afraid of getting dirty. I also recomend flushing your brake system and installing stainless steel brake lines. I used synthetic brake fluid, like DOT5 lol I swear my braking is much more responsive and stiff, I also needed new front rotors and did that at the same time so how much the lines did for me I am not quite sure.
To do the brake calipers and rotors you are going to need:
Pry bar or big a$$ flat head screwdriver
Big C clamp
Needle nose pliers
Socket set
Tire iron
ofcourse you will need the parts, ie: rotors, pads, brake fluid, calipers, ect...
PS. guys help me out if i forgot something..........
Big C clamp
Needle nose pliers
Socket set
Tire iron
Big C clamp
Needle nose pliers
Socket set
Tire iron
Big C clamp
Needle nose pliers
Socket set
Tire iron
-King Ryan-
Originally Posted by slammed95
I'm sure you can find an experienced maxima owner in your area that has done many B.J.'s
Just ask around, someone will help you out.
http://www.motorvate.ca/mvp.php/300
Originally Posted by Midknight MAXX
For a Max b.j. make sure you service the rear calipers correctly or you'll be buying some more. You can't just use a clamp to force the piston back in you have to screw it.
i just got a B.j right now
now i feel much safer
cant wait to get a bj , its been so long , i remember my first bj, we had our own "mechanic" right across the street, it was nice bc at 14, 15 yrs old i was gettin bjs done while otha kids were building legos, oo those were the good times, i wish i neva moved , i loved that "mechanic n wat she could do , so from gettin bjs on bikes now to cars
-King Ryan-
-King Ryan-
a bj is good for one and all.... young and old...
I know i'm definitly in need of one. It always seems to make the ride quality so much better. With all that pressure built up, a good bj will improve performance and smooth things out in every way. The advantage for those that don't consider this a DIY project or can get some local assistance, the pros aren't took expensive to handle the job.
time for a bj
time for a bj
TurboS13Hatch
04-20-2010 07:09 PM
TurboS13Hatch
03-19-2010 10:03 PM
TurboS13Hatch
03-19-2010 02:48 PM
