Injector replacement
Old Oct 1, 2003 | 04:38 PM
tweaked's Avatar
Here is where I am:
I removed the intake manifold, and removed cylinder #1 injector which is fried (no continuity/resistance)
Some on this forum recommend only to replace the faulty injector and the dealer recommend to change them all (3 under the manifold) as they are a hell to replace.
-Are they prone to fail after 120,000 miles? If so, should I replace them all.
-Are rebuilt as good as the new ones?
-Should I remove the carbon deposit from the EGR connector and the plenum? If yes, what should I use?
Thanks again for all your help you gave me up to now,
Stephane
Old Dec 17, 2003 | 09:00 AM
Ladzio's Avatar
Originally Posted by tweaked
Here is where I am:
Stephane
Hey, found your post, I am going to change injector in cyl #1 tonight. Never removed IM before. Is there anything I should look out for when removing IM?
Did you put new O-rings with new injector or reused old ones?
How much time it took you?
I can't find any write-ups or any pictures so Haynes manual will be my only guide.
Thanks,
Vlad
Old Dec 17, 2003 | 04:02 PM
Ladzio's Avatar
anyone? any tips/opinions/advices/suggestions/.....
no one took off the IM before
....people with MEVI come to mind
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
TheMafia
Sep 4, 2015 08:26 AM
