differential bearings and a turbine like whine in 1st gear...
Old Oct 1, 2003 | 10:18 PM
michaelnyden's Avatar
I have a turbine like whine in 1st gear....characteristic of failing differential bearings....nevertheless, how long can i run on these bearings b4 failure? What will happen when they fail....will the tranny just take a dump on me and refuse to go anywhere? in either case, I am looking at a 5spd LSD tranny to replace it with and i forgot that site url where you select the part you want...and it returns where and what company is selling and for how much.....its kinda like a huge classifieds online for specific car parts/components....anyway...i understand i will also need only the driver side axle correct?
Old Oct 1, 2003 | 10:25 PM
nadir_s's Avatar
vicodin ... gift of life
i ran 10k miles on bad bearings. It never died on me... i just got sick of the leaking and junk and had it rebuilt.
and yeah, you understand right a bout the LSD/axle.
Old Oct 1, 2003 | 11:16 PM
nismos14's Avatar
§è~® f®ÈÄk
before u go having things done, how long have you been having this whine? and does it also happen in reverse?
Old Oct 1, 2003 | 11:23 PM
krue92's Avatar
My maxima has a whine, groan or whatever you want to call it in first and reverse. They both have a different sound to them, but it doesn't sound to odd to me. I have had the car for 4K miles and it has done it since I had it. I changed the tranny fluid and I saw no shavings in the fluid. I just recently changed my axles and I have no play in them. I really think it is just a standard low gear groan that I am getting, but who knows. I have read other guys who have driven a lot of maximas and they all make noises in first in reverse.
Old Oct 1, 2003 | 11:37 PM
Nismo's Avatar
reverse will always wine on any manual car due to the non-helical(spelling) gears.
Old Oct 2, 2003 | 07:33 AM
nismos14's Avatar
§è~® f®ÈÄk
mine does it in first and reverse too thats why i dont think its too big of an issue unless he has shavings or a leak
Old Oct 2, 2003 | 08:52 AM
blizz20oma's Avatar
I'm so hood
Right - check for other tell-tale symptoms as in leakage before you go swapping out the trannies. Whine in 1st and R are normal. If you get whine in 2-5, that's usually an indication along with leakage/axle play.
Old Oct 2, 2003 | 10:53 AM
I30tMikeD's Avatar
Also, remember that the 5-speed LSD tranny's from either and I30 or a CDM max also are **** to bearing failure. So what ever you buy have the bearing shim checked before install.
Old Oct 2, 2003 | 10:54 AM
Ladzio's Avatar
I have been searching the forum but could really find what problem I have. Sometimes, especcially when tranny is cold I have difficulty switching into 1 gear (I have 5sp), I kinda need to push it there and it is even worse with reverse (I shift into 1 and 2 and then it would go into R somehow). Are the bearings dead already....???
Enormous thanks in advance!!!
Old Oct 2, 2003 | 01:46 PM
I30tMikeD's Avatar
No 123234567
I30tMikeD's Avatar
No 123234567
nismos14's Avatar
§è~® f®ÈÄk
that has nothing to do with ur bearings, try and see if when u want to go into reverse u press the clutch in again instead of staying on it, that might help.... i dont know what else to say except that it COULD possibly be ur synchro's
Old Oct 2, 2003 | 01:59 PM
Ladzio's Avatar
Thanks for an answer. I made mistake in my first sentence, I ment I serached forum but did not find exact reason for my problem. I am not that well technically familiar with car but as DIY mechanic I could be.
Hey, I30tMikeD, what did you mean with 'No 123234567', thread number...??
Old Oct 2, 2003 | 02:13 PM
I30tMikeD's Avatar
no 12344566777
Old Oct 2, 2003 | 02:17 PM
Ladzio's Avatar
Originally Posted by I30tMikeD
no 12344566777
A little more explanation will be much appreciated!!
Old Oct 2, 2003 | 04:04 PM
Flava_24/7's Avatar
Boosted Panda
Post have to be at least 10 characters.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
Pied
Sep 26, 2015 03:29 PM
