Flashing lights help
Old Oct 3, 2003 | 07:09 AM
fast50ranger's Avatar
I have a 96 Max and Monday the charge and brake warning lights flicker on and off. It doesn't do it all of the time. The battery in the car is about 2 years old. I took it to have the alternator and battery checked and everything checked out ok. Any suggestions or solutions would be appreciated before I have to take it to the 'stealer'. Drivability is not affected by the lights flickering.
Old Oct 3, 2003 | 08:23 AM
SuperFishstick's Avatar
well, the brake warning light, if that flashes it usually means you might be low on brake fluid. As for the charge light?, maybe a bad connection?
Old Oct 4, 2003 | 09:15 AM
SilencingMachin's Avatar
You may need an alternator -- I had the same thing happen to me. The voltage regulator in the alternator went, and my car was charging at 16+ volts. If I left all the acessories on, and the blower on high it wasn't that bad... but if I didn't have the headlights, seat heaters, and everything else on -- every time the engine reved up those lights would go on and off... I ended up getting a red top optima and a new alternator...
Old Oct 4, 2003 | 03:12 PM
maxdis1's Avatar
Ok my friend , I have had a similar experience with my previous 3rd Gen. The problem was (in my case) a bad brake master cylinder. You may want to check it with your local mechanic or , muster up the courage and go to the dealer Do not disregard this light! I could be other things in your situation ,i.e sticky caliper,ect.
Old Oct 5, 2003 | 07:53 AM
njmaxseltd's Avatar
Brake light + Charge light = Alternator
It's probably on it's last legs.
fastcarny
Oct 6, 2015 10:42 AM
bryants95max
Oct 2, 2015 12:52 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
intimidator
Sep 5, 2015 07:23 PM
