A/C charged but warm air?
Old Oct 4, 2003 | 04:34 PM
RammaR's Avatar
I haven't used the A/C on my '95 SE for a few days but turned it on today again and got only warm air. My first thought was that it was low on R-134 but I checked the pressure and its in the "normal" range on my gauge - but its on the lower edge of range I guess. I can hear the compressor turning on and off with the A/C button so its not an electrical problem - I even checked the relay just to be sure. So I'm a bit confused if the pressure is good and the compressor is running - what's next to check? The "cold" side isn't hot but its not very "cool" either. I'm a little worried about overcharging the system if I add another can of freon - any suggestions? I'm hoping its not a problem with the compressor itself.
Thanks for the help.
Old Oct 4, 2003 | 07:12 PM
1996blackmax's Avatar
Do not add another can of refrigerant! I overcharged my system and I ruined my condensor($185). I had the same problem you are having, and did the same thing you did, but then I added more, and had more problems. My car was smoking when I pulled over to pick up my kids at school, it was the refrigerant and oil coming out from the condensor and hitting hot under the hood parts. If I would of just paid the $90 dollars to get it checked out, I would of only had to replace my compressor. I paid $340 dollars for an OEM one from my local Nissan dealer. Now it is nice and cold. My advice is to take it to a professional mechanic experienced with a/c stuff.
Old Oct 4, 2003 | 09:05 PM
RammaR's Avatar
Thanks - I'll have to try that Monday.
Old Oct 4, 2003 | 09:55 PM
Dave Holmes's Avatar
Check that BOTH fans come on when AC is turned on.
Dave
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
